how to draw interrupted lines
how to draw interrupted lines 3052192 03 Apr 17:19
  how to draw interrupted lines Daniel Hauck 05 Apr 11:25
  how to draw interrupted lines Owen 05 Apr 23:05
3052192
2013-04-03 17:19:35 UTC (over 12 years ago)
Hi friends,
how can I draw in GIMP freehanded curved
interrupted lines (dotted; dot-dash-dot; dash-dash;...) ?
To create lines first with a pencil and to use then the rubber
gives uneven and so unsatisfactory results.
Thanks for help!
Konrad
Daniel Hauck
2013-04-05 11:25:22 UTC (over 12 years ago)
I think you can't really do that. But I will write up a little on how to work with the paths tool to achieve what you want. It was Inkscape which taught me how to use the paths tool the best, I think, because the way Inkscape works, it's all lines and paths and the like.
I have to go to work now, but will try to steal a few moments to put something together for you. I think then it will become much clearer.
But the short answer is "paths tool" and "paint along path."
On 04/03/2013 01:19 PM, 3052192 wrote:
Hi friends,
how can I draw in GIMP freehanded *_curved_*
Thanks for help!
Konrad
gimp-user-list@gnome.org
Owen
2013-04-05 23:05:38 UTC (over 12 years ago)
On Wed, 3 Apr 2013 19:19:35 +0200 "3052192" wrote:
Hi friends,
1. Use the Paths Tool to create and edit your shape
2. Make it a selection
3. Stroke selection and select custom stroke (there is a dot dash there)
Owen
