changing shortcut keys
changing shortcut keys Gaston Garcia 14 Jul 01:00
  changing shortcut keys Joao S. O. Bueno 14 Jul 05:12
   changing shortcut keys Gaston Garcia 15 Jul 01:53
Gaston Garcia
2004-07-14 01:00:15 UTC (almost 21 years ago)
hi, I'm having problems changing the shortcut keys in The Gimp 2. What is the order of steps in order to change a shortcut. For example make Zoom tool have "z" as key.
thanks
Gaston.
Joao S. O. Bueno
2004-07-14 05:12:01 UTC (almost 21 years ago)
Hi Gaston!
Unfortunattely, GTK mnemonics (i.e. key acelerators in the menus), broke the pratical way odf dinamycally assigning shortcuts on The Gimp.
You can turn on "dinamic shortcuts" on the preferences dialog - but taht will allow shortcuts like "shift + z" and "ctrl + z"...the only way, in GIMP 2.0.X to reliably assign single letter shortcuts to commands is to manually edit your ~/.gimp-2.0/menurc file .
JS ->
thanks
Gaston.
Gaston Garcia
2004-07-15 01:53:01 UTC (almost 21 years ago)
Thanks ok, I'll try that.
gaston
Hi Gaston!
JS ->
thanks
Gaston.
