newvie asks differences between Gimp and Photoshop
- postings
- 14
Hi everyone.
I have just uploaded Gimp2 onto my computer after having a massive crash a few weeks ago. I had Photoshop CS4 on it previously, but I no longer have a useable software disk for it and in all honesty I cannot justify the cost of getting it again for what I do. So my question for now will be straightforward.
My first impression of Gimp was that it was a little awkward, but I'm getting used to it now. The main thing I use this type of software for is making signatures for my forum. Like this one
[IMG]http://i811.photobucket.com/albums/zz37/melanieoz/My%20Sigs%20and%20stuff/NewElleSiggy.jpg[/IMG]
When I make these, taking stock photographs and using the lasso selection tool in CS4, I have an option by right clicking on my selection and choosing 'feather' which softens the edges of the selection and makes it look less like a simple cut out. Does anyone know how to achieve the same result with Gimp?
Of course I know I'll have a lot more questions later
Select the lasso (actually, any) selection tool in GIMP, check the "feather" and possibly "antialiasing" checkbox(es), then make your selection. You can adjust the amount of feathering; the feathering will approximately bridge the selection line, so the selection will include roughly r/2 pixels outside the line and r/2 inside, where "r" is the feathering "Radius". The number "r" can be as small or as large as you like, in tenths of a pixel.
On 21 Jan 13 23:49 RogueRanger said:
I have an option by right clicking on my selection and choosing 'feather'...Does anyone know how to achieve the same result with Gimp?
Make your selection, right-click anywhwere on the image, choose "Select" then "Feather", choose the feathering options on the dialogue that appears. How much easier/similar do you want? :-)
Greg Chapman
http://www.gregtutor.plus.com
Helping new users of KompoZer and The GIMP
- postings
- 14
thank you both. I thought it would be similar and I did try that. But the lasso arc was still active and I wasn't able to end it. What am I doing wrong?
Assuming you need a consistent size for your thumbnails, here's a workflow for that.
Part one, crop and scale the source image to the required dimensions:
Make a rectangular selection of any size in the upper left corner of the source image.
Go to the Tool Options tab in your dock, which will display settings for your selection area. In the Size boxes, enter the size of your finished image in pixels. Then select Fixed Aspect Ratio.
Back on the image canvas, move and resize your selection until it frames the subject properly. Then do Image > Crop To Selection.
Next up, do Image > Scale, and enter the size your finished web image should be. When you set the width, the height should automatically come out right. (Within one pixel or so.)
Part two, the feathered edge:
Select > All
Select > Shrink (adjust radius to suit your needs)
Select > Feather (adjust radius to suit your needs)
Select > Invert (or, Ctrl+i)
Delete (or, Ctrl-x)
File > Export, and save as PNG (or, Ctrl+e and proceed from there)
This will give you a well composed image of the desired size, with a feathered, anti-aliased edge that blends with whatever background color the web page in question presents.
:o)
Steve
Hi Rogue,
Just double-click on the final point and it will join with the original point automatically to enclose the lassooed area.
The tool itself will remain the selected one until you select another.
Greg Chapman
Still exploring BlueGriffon
- postings
- 14
Thank you again, I did work that one out. But in general I don't know if it's just me, but I am really stressing out getting anything done, it just seems so strange to me. First up I have Aspergers so I suppose that doesn't help.
These are some things that make it hard for me. The tool menus unlike PS are not a part of the main window and seem to be seperate windows on their own (2 of them) that is annoying
everytime I create a new area, (layer) it opens in yet another window, as does opening up another file. So if I'm trying to do a signature and I'm using 3 or even four items, I have that many seperate windows open.
Also the rectangular selection tool seems to be on all the time whether I select it or not. I've tried deleting the software and reinstalling but that doesn't work
Have you tried turning on:
Windows > Single-window mode ?
Greg Chapman
You can turn on single-window mode mode by right-clicking -> Windows -> Single-Window Mode
This isn't usual GIMP-behavior. You should check, whether you're actually creating new layers or new images. To do so, look at the layers-dialogue (usually located to the right of your canvas, you can also find it by pressing Ctrl+L). When you create a new layer (resulting in a new window being opened), are there two layers shown in the dialogue or is it actually a new stack of layers (= new image) with just one layer in it?
Do you mean all the time as in "I cannot select i.e. the paintbrush
tool"? That would be some pretty serious bug, assuming you know basic
point-and-click interaction.
However, seeing how you're already talking about adding signatures and
stuff, it seems more likely that you're confused by the rectangular
select being the default tool which is active upon startup and often
becomes the active tool after a task is performed. In Photoshop, the
default tool is the move tool and you have to select the rect. select if
you want to use it, in GIMP it's the other way around. It may seem
unnatural to you due to what you're used too, but it's not "better" or
"worse" than Photoshop's way (at least there haven't been any user
studies about it) and I can guarantee you, that it's just as hard
learning Photoshop after using GIMP as the other way around.
Since there will be similar cases in the future, there is something that
you should really try to understand: Despite being often described as
such, GIMP is not "Photoshop for free" or "Photoshop but not as
powerful" or otherwise "like Photoshop". It is a
bitmap-manipulation-program (actually an xcf-manipulation-program, but
let's not dive into that), that is separate and different from Photoshop
and therefore, some of the operational concepts are different from
Photoshop's. Sometimes things won't be were they "of course" (also
called: where you've been trained to expect them by your prior program
usage) should be, and sometimes you'll be pleasantly surprised by how
they are arranged in the GIMP. Switching to GIMP isn't 1:1, but if you
accept that GIMP may follow other premises than Photoshop, and that
those premises aren't automatically bad just because of that, getting
used to them isn't really all that hard.
So if everything goes right, this was at least a little helpful,
bw, Tobias Lunte//Tobl
- postings
- 14
d'oh..... facepalm..
it works, I didn't even know it was there......
thank you again and sorry to be a pest
I'm sorry if you get this email twice, but it was returned to sender so I'm not sure which of the recipients haven't gotten it.
- postings
- 14
I'm glad you did ^_^
reading all through I'm slowly coming to terms with it. I'll post my first Gimp Sig for you soon
Melanie
- postings
- 14
First siggy made although I'm not totally happy with the font and how it came out. Is there a way to highlight it?
Gimp siggy
- postings
- 14
this is what I had before, you can see the difference with the text
Allienna
