scanner works with linux
9 of 9 messages available
scanner works with linux Gracia M. Littauer 29 Nov 13:15
  scanner works with linux Patrick Shanahan 29 Nov 19:54
  scanner works with linux Chris Mohler 29 Nov 20:11
   scanner works with linux Martin Goose 29 Nov 21:12
    scanner works with linux Jay Smith 30 Nov 01:00
     scanner works with linux Jeff P. Zacher 30 Nov 01:46
     scanner works with linux Liam R E Quin 30 Nov 05:42
  scanner works with linux maderios 30 Nov 09:00
  scanner works with linux Robert Smits 05 Dec 01:31
Gracia M. Littauer
2012-11-29 13:15:41 UTC (over 12 years ago)
I know the Epson Stylus Photo 1400 it's 8 years old anyone recomend any newer good Epson scanner that work with linux?
Gracia in Cooleemee, NC- on Zenwalk 6.2
http://www.flickr.com/photos/mynameistaken/
http://www.youtube.com/bellalight
Cogito, ergo sum
Patrick Shanahan
2012-11-29 19:54:27 UTC (over 12 years ago)
* Gracia M. Littauer [11-29-12 13:18]:
I have a 2400 that worked good.
(paka)Patrick Shanahan       Plainfield, Indiana, USA      HOG # US1244711
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
http://en.opensuse.org                           openSUSE Community Member
Chris Mohler
2012-11-29 20:11:00 UTC (over 12 years ago)
On Thu, Nov 29, 2012 at 7:15 AM, Gracia M. Littauer wrote:
anyone recomend any
No, but I would check definitely check SANE support status before purchasing: http://www.sane-project.org/sane-mfgs.html#Z-EPSON
Chris
Martin Goose
2012-11-29 21:12:09 UTC (over 12 years ago)
Chris
I am still using an Epson Perfection 1650 scanner with Linux. It must be at least as old as yours.
This may help:
Martin
Jay Smith
2012-11-30 01:00:50 UTC (over 12 years ago)
No, but I am using a couple "Epson Perfection 4490 Photo", probably as old as what you have. They work great on Ubuntu Linux (with some tweaking of linux USB stuff due to the older Linux distribution we are still using).
In any case, more importantly, we use the scanners through Hamrick's VueScan Professional scanning software and love it!
http://www.hamrick.com/
I have had questions about our scanning workflow, color calibration questions, and selection of LARGE (11x17) format scanners. I have asked Ed Hamrick and he has always been quick to answer with very helpful information. For me, that alone is work the modest price of the program. [We ended up with a used/refurb Epson GT-10000 large format scanner which is incredible (faster and better than the usual smaller scanners even though it is a lot older). Original price probably around $5000 back in the day, but I found a used one for $400 -- plus delivery by truck.]
Very importantly, Hamrick has a huge supported scanners list http://www.hamrick.com/vuescan/vuescan.htm#supported that tells you (by specific scanner model if you want to check on one) if it is "supposed" to work on "linux" (generically, at least).
I would not dream of doing the scanning work we do without VueScan.
I also found it extremely useful for our particular scanning work to calibrate the scanners, using a 'target', which I obtained from a source in Germany. Targets can be very expensive, but this one was only about $30 as I recall -- the best and the best deal I was able to find. VueScan does support use of the generated calibration file that is created as result of calibration process. [Now I just need to get calibrating equipment for our monitors, but that is a lot more costly.]
Jay
Jeff P. Zacher
2012-11-30 01:46:22 UTC (over 12 years ago)
http://www.sane-project.org/sane-supported-devices.html check this if you use sane...
Jay _______________________________________________ gimp-user-list mailing list
gimp-user-list@gnome.org
Liam R E Quin
2012-11-30 05:42:13 UTC (over 12 years ago)
I use the Epson Expressionist 10000 XL for www.fromoldbooks.org - it's a large-format scanner that I've heard described as "museum quality". It included a calibration target and (proprietary Windows-based) software to use it. I've had it for about 7 years, but they are still sold I think.
It all depends what you mean by "good", really, and your budget.
Liam
maderios
2012-11-30 09:00:55 UTC (over 12 years ago)
"Newer", why ? Epson perfection V750 (pro or not pro) is a very good scanner and it works perfectly with GNU/Linux
Greetings
Maderios
"Art is meant to disturb. Science reassures."
"L'art est fait pour troubler. La science rassure" (Georges Braque)
Robert Smits
2012-12-05 01:31:59 UTC (over 12 years ago)
I don't know its age, but I find an EPSON 4490 works well with OpenSuse and the Epson software.
Bob Smits
"Microsoft is not the answer. Microsoft is the question. NO is the
answer." - Erik Naggum
