build problem
build problem Gary Aitken 09 Nov 23:17
  build problem Kevin Cozens 10 Nov 01:29
Gary Aitken
2012-11-09 23:17:23 UTC (almost 13 years ago)
build problem
I'm trying to build 2.8 on freebsd. As a starting point, I'm trying to build only babl-0.1.10 I've downloaded the tarball and unpacked it. then:
cd /usr/local
mkdir -p gimp-2.8/lib/pkgconfig
mkdir gimp-2.8/bin
export PATH=/usr/local/gimp-2.8/bin:$PATH export PKG_CONFIG_PATH=/usr/local/gimp-2.8/lib/pkgconfig export LD_LIBRARY_PATH=/usr/local/gimp-2.8/lib cd ~/Computing/GIMP/work_2.8/babl-0.1.10 ./autogen.sh --prefix=/usr/local/gimp-2.8
make make all-recursive
Making all in babl
"Makefile", line 1013: Missing dependency operator make: fatal errors encountered -- cannot continue
babl/Makefile line 1012-103 looks like this:
# GObject Introspection -include $(INTROSPECTION_MAKEFILE)
INTROSPECTION_MAKEFILE is set empty early on in babl/Makefile
It is also set empty in the top level Makefile, along with all the other INTROSPECTION_* symbols plus a few others like LDFLAGS and LIBOBJS
I'm guessing there's something additional I need to do either in terms of flags passed to make or autogen, or else some environment vars needed to get the gnome build environment correct.
help?
Thanks,
Gary
Kevin Cozens
2012-11-10 01:29:31 UTC (almost 13 years ago)
build problem
[snip]
[snip]
Add "--enable-introspection=auto" or set it to "no" if you don't have the introspection support packages.
