Work with a MEDION graphic tray
Am 21.09.2012 16:19, schrieb Jernej Simončič:
On Thu, 20 Sep 2012
13:03:28 +0200, Jakob Neumann wrote:
I have asked MEDION already, but
they said, I have to
ask the software producers.
Try this: uninstall
GIMP 2.8, then run the 2.8.2 installer with /32
parameter (to do this,
press the Windows key and R on keyboard, so that the
Run dialog opens;
then click Browse and find gimp-2.8.2-setup.exe; back in
the Run dialog
add a space and /32 at the end of Open field and click OK).
This'll
install 32-bit version of GIMP instead of 64-bit one if you have
64-bit
Windows. If the tablet works now, you should contact the
manufacturer,
and request 64-bit drivers for the tablet.
Thanks alot.
I'm not the
OP of this thread, but at least my variant of this bug (reported in the
gimp-dev version of this thread and here
https://bugzilla.gnome.org/show_bug.cgi?id=674232 [1]) could be resolved
this way. I'll mark the bug-report solved.
Links:
[1]
