Editing Multi Images
Editing Multi Images N Q Suzumeh 19 Aug 18:59
  Editing Multi Images Alexandre Prokoudine 19 Aug 19:07
  Editing Multi Images fmc 19 Aug 21:07
  Editing Multi Images Kevin Cozens 19 Aug 21:35
   Editing Multi Images Partha Bagchi 19 Aug 21:53
  Editing Multi Images Liam R E Quin 21 Aug 17:06
N Q Suzumeh
2012-08-19 18:59:28 UTC (over 12 years ago)
I want to scale down a set of 125 images. Is there another way to do this other than one at a time? Prue's Doux
2012-08-19 19:07:20 UTC (over 12 years ago)
Of course :)
Please just use any batch processing software. There's plenty of such applications. Phatch comes to mind as one of them.
Or you can install something like http://www.alessandrofrancesconi.it/projects/bimp/ for GIMP.
fmc
2012-08-19 21:07:40 UTC (over 12 years ago)
Prue's Doux
Better to use something like mogrify from the display package rather than GIMP for something like this.
Frank
Kevin Cozens
2012-08-19 21:35:33 UTC (over 12 years ago)
Check out ImageMagick. I seem to remember I used it once before to do a bulk modify. Look at convert or mogrify.
Partha Bagchi
2012-08-19 21:53:29 UTC (over 12 years ago)
-- Cheers!
Kevin.
Right!
Since you didn't mention OS, you can try this with Linux, Apple terminal, or Msys in Windows:
for i in *.jpg; do out=$(ls $i | sed -e 's/.jpg//g')
convert "$i" -resize 1024 "$out-s.jpg" done
Liam R E Quin
2012-08-21 17:06:34 UTC (over 12 years ago)
Most Linux distributions include ImageMagick, and you can do, e.g.
mkdir precious-originals cp -a *.jpg precious-originals
(This will also work on OS X; in both cases you may need to install imagemagick)
If the files are GIMP-native (xcf, xcf.gz, etc) then use one of the various gimp batch processors - there's one called David's Batch Processor on gimp.org.
Liam
