how to fill...
how to fill... scythargon 14 Aug 13:32
  how to fill... Chris Mohler 14 Aug 15:16
   how to fill... SavvySaffer 17 Aug 05:59
  how to fill... Joao S. O. Bueno 17 Aug 19:27
2012-08-14 13:32:46 UTC (over 12 years ago)
how to fill...
I have area(the whole layer) that I have filled with semi-transparent gradient, so now, I select it - (layer->alpha to selection) and trying to fill with ordinary non-transparent color, but I get the same area with the same semi-transparent gradient, the only thing that I changed - the main color of gradient:(
Chris Mohler
2012-08-14 15:16:45 UTC (over 12 years ago)
how to fill...
You're selecting only the alpha channel. On that layer, "Select All", then fill.
Chris
2012-08-17 05:59:51 UTC (over 12 years ago)
how to fill...
Chris
The Alpha Channel is a greyscale channel that only contains information about the transparency of the pixels in the layer. When you select by alpha channel, you're only selecting the part of the image with non-zero 'opaqueness'.
Joao S. O. Bueno
2012-08-17 19:27:47 UTC (over 12 years ago)
how to fill...
I am not shure about what you actually want to achieve, but it sounds like you could make use of the "behind" paint mode (change, on the tool options, the paint mode from "normal" to "behind". )
js
scythargon (via gimpusers.com)
gimp-user-list@gnome.org
