gimp color selector like in GNU Paint
gimp color selector like in GNU Paint Enda 23 Jul 17:09
  gimp color selector like in GNU Paint Alexandre Prokoudine 23 Jul 21:38
  gimp color selector like in GNU Paint Gfxuser 28 Jul 14:40
gimp color selector like in GNU Paint Jernej Simončič 23 Jul 21:52
  gimp color selector like in GNU Paint Alexandre Prokoudine 23 Jul 21:55
Enda
2012-07-23 17:09:52 UTC (almost 13 years ago)
Is there a gimp color selector like in GNU Paint?
- Enda
http://upload.wikimedia.org/wikipedia/commons/5/5e/Gpaint-0.3.3-ubuntu.png
2012-07-23 21:38:52 UTC (almost 13 years ago)
Please do not expect everyone to know what GNU Paint is and how its color selector works. Rather than naming feature, please try to explain what is it that they actually do.
Jernej Simončič
2012-07-23 21:52:01 UTC (almost 13 years ago)
He did link a screenshot at the bottom of his e-mail:
Looks like PaintBrush/MS Paint clone.
2012-07-23 21:55:43 UTC (almost 13 years ago)
Yes, but that doesn't explain what's so special about color picker in GNU Paint.
Even if actually color palette in the bottom was meant instead, I don't see how it's terribly different from GIMP's swatches.
Gfxuser
2012-07-28 14:40:29 UTC (over 12 years ago)
Am 23.07.12 19:09, schrieb Enda:
- Enda
I guess, you mean the color palette at the bottom of this screenshot, don't you?
To select a foreground or background color in a similar easy way like GPaints color palette, do the following: 1. Under the tools palette (usually on the left window border) you find the color selectors: two overlapping, black and white filled rectangles. If you don't find them, press the d (lowercase) key and search again. 2. Click into the white or black rectangle. 3. At the upper left side of the next dialog window, click on the pipette register tab. A grid with a color palette will show. The default color palette shows a basic set of colors similar to those in GPaint. 4. Select a color from the grid and confirm the dialog.
If you'd like to have a color palette similar to that in GPaint, save the selected color with the little '>' button in the lower middle of the color dialog. You can then further select it from the color palette in the lower right of this dialog.
You find more information about the color selection dialog at http://docs.gimp.org/2.6/en/gimp-dialogs-content.html#gimp-color-dialog.
It's not that straightforward like in GPaint, but both programs have different goals. While GPaint is meant to be very simple like MS Paint, GIMP is an advanced photo editing application.
Best regards,
grafxuser
