GIMP 2.8 usability discussion - Argument consolidation and referencing
Johannes
2012-07-14 10:47:38 UTC (almost 13 years ago)
Having followed the discussions on the GIMP usability changes for some weeks now, what I am missing most is a direct comparison of arguments.
Therefore let's consolidate the consensus and the arguments pro and contra "Making the new open/save/export behavior of GIMP 2.8 optional" by giving argument abstracts and links to good arguments, i.e. giving references!
If there is a good argument, you don't have to fully repeat it, just give a short link and a short abstract (especially if the argument is too bloated or its core is hard to recognize).
This is the consensus so far (correct me if I am wrong):
### CONSENSUS:
There is no "the user". There are all kinds of folks with different habits, workflows.
On the one hand, there are "heavy-weight workflows". The main characteristic of this kind of workflow is the requirement of closing and re-opening one "high quality" working copy, and tasks like saving/exporting frequently as both JPEG and XCF, exporting JPEGs for comparisons, possibility to go back and alter steps throughout the whole workflow. The most important aspects of this kind of workflow is preserving image quality and preserving flexibility."
On the other hand, there are "lightweight workflows". The main characteristic of this kind of workflow is that there is no need for closing and re-opening the image. The most important aspect of this kind of workflow is efficiency.
http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00014.html
The following are the arguments I found so far. Everybody is invited to replace weak arguments by stronger ones or to add missing arguments --just don't forget to give references.
## PRO:
* Abstract: "The previous file open/save/export behavior met the needs of all users."
http://mail.gnome.org/archives/gimp-user-list/2012-June/msg00228.html http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00056.html
* Abstract: "If the Save/Export separation would be the default setting and could be disabled, then every GIMP user could be happy. The "heavy-weight workflow" users just leave the default setting enabled, and the "lightweight workflow" users disable it at their own risk." http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00008.html http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00047.html http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00056.html
* Abstract: "There is no convincing argument so far to _not_ make this separation optional. It not even seems complicated to implement a switch for this behavior on the technical level." http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00025.html
* Abstract: "A GIMP fork because of such a little change that can be made optional makes no sense."
http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00064.html
## CONTRA:
* Abstract: "No." http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00009.html http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00057.html
* Abstract: "Users who don't like the new open/save/export behavior can use another software than GIMP."
http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00014.html http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00045.html
* Abstract: "Open-source software is a meritocracy, not a democracy. Users who do not implement, should not complain. Stating and explaining opinions is no merit."
http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00063.html
* Abstract: "The PRO arguments only reflect the opinion of a few. Therefore this is not important."
http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00011.html http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00063.html
* Abstract: "Everything convincing has been said elsewhere." http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00011.html http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00012.html http://mail.gnome.org/archives/gimp-user-list/2012-July/msg00026.html
* Abstract: "not the often touted ‘prosumer photo jpeg–to–jpeg’ workflow, because for complying with the GIMP product vision there is no need for optimising this"
http://gui.gimp.org/index.php/Save_%2B_export_specification
Of course, the mere count of links doesn't say anything. Therefore the argument abstracts should be preferred.
If it appears too circumstantial even to give a link to a good argument, this is a direct contradiction to the "everything convincing has been said elsewhere" argument.
A good starting point for finding arguments is the GIMP mailing list archive ("haystack"):
http://mail.gnome.org/archives/gimp-user-list/ http://mail.gnome.org/archives/gimp-developer-list/
- or Google ("needle finder") --try it with the "site:mail.gnome.org/archives/gimp-user-list/" or "site:mail.gnome.org/archives/gimp-developer-list/" options.
Alexandre Prokoudine
2012-07-14 14:34:09 UTC (almost 13 years ago)
And what will it be good for?
Chris Mohler
2012-07-14 14:45:11 UTC (almost 13 years ago)
### CORRECTED
There are a handful of people developing GIMP. They are following this: http://gui.gimp.org/index.php/Save_%2B_export_specification
Based on this: http://gui.gimp.org/index.php/GIMP_UI_Redesign
You can:
A: Bitch
B: Adapt
C: Fork
I suggest option B or C - they're likely to be the most productive.
HTH, Chris
(Note that I'm not a developer - just a user that's getting a bit tired of certain threads)
Ken Warner
2012-07-14 16:06:43 UTC (almost 13 years ago)
Well, that is the question isn't it?
gimp-user-list@gnome.org
Johannes
2012-07-14 17:24:09 UTC (almost 13 years ago)
Am 14.07.2012 16:45, schrieb Chris Mohler:
You can:
A: Bitch
B: Adapt
C: Fork
In fact, I am preparing option B.
Precondition for this is a good understanding of what is to be adapted. I don't want my changes to be simply reverted, because I would be a newbie committer and others may like to play power games or something.
Don't get me wrong, I want to make things better, not cast perls before people without arguments.
Johannes
2012-07-14 17:28:06 UTC (almost 13 years ago)
Am 14.07.2012 19:24, schrieb Johannes:
...and no pearls, too.
2012-07-14 18:41:21 UTC (almost 13 years ago)
You can:
A: Bitch
B: Adapt
C: Fork
Your workflow, to the way GIMP 2.8 works now.
HTH, Michael
scott s.
2012-07-15 00:56:50 UTC (almost 13 years ago)
### CORRECTED
You can:
A: Bitch
B: Adapt
C: Fork
Thanks for the refs. It makes for better understanding. In studying the specs something I don't understand is why there is an apparent distinction being made between file open behavior and file save. It seems to me that opening vice import has many of the same issues/ useability requirements that should be considered. In particular, a problem I encounter with workflow in GIMP is that GIMP doesn't really handle (AFAIK) meta-data embedded with image raster data in file formats (in my case, Tiff tags). Treating import in a manner analogous to export (ie, import and export may cause loss of data) seems reasonable (if only to me of course).
scott s. .
2012-07-15 01:43:29 UTC (almost 13 years ago)
Reading metadata from TIFF has nothing to do with opening, importing, saving or exporting. GIMP currently relies on libtiff library which doesn't read or save embedded metadata. That's all :)
Richard Gitschlag
2012-07-15 02:23:58 UTC (almost 13 years ago)
Date: Sat, 14 Jul 2012 14:56:50 -1000 From: 75270.3703@earthlink.net
To: gimp-user-list@gnome.org
Subject: Re: [Gimp-user] GIMP 2.8 usability discussion - Argument consolidation and referencing
scott s. .
Metadata is, almost by definition, non-essential to the layer and pixel composition of an image; so the fact GIMP ignores it during load only makes a difference if you need to write said composition back to a TIFF file with original metadata preserved. (Which is, of course, little consolation if your particular workflow relies on this.)
scott s.
2012-07-15 23:40:15 UTC (almost 13 years ago)
> handle (AFAIK) meta-data embedded with image raster data in file formats > (in my case, Tiff tags). Treating import in a manner analogous to > export (ie, import and export may cause loss of data) seems reasonable > (if only to me of course).
> scott s.
Agreed, which is why my argument is that "file -> open" means to open a GIMP project file, i.e. xcf. Using other file formats would require a "file -> import" action, which implies that the file is being converted to GIMP's project format and of course may result in loss of data that GIMP doesn't import. This would be completely analogous to save/export. This is the behavior I am familiar with in various 3d design software: importers, exporters, and renderers for the native project format.
scott s. .
