Problems with Gimp on Ubuntu
Problems with Gimp on Ubuntu beelissa 30 Jun 21:17
  Problems with Gimp on Ubuntu Alexandre Prokoudine 30 Jun 21:54
   Problems with Gimp on Ubuntu beelissa 01 Jul 02:28
    Problems with Gimp on Ubuntu Alexandre Prokoudine 02 Jul 19:27
2012-06-30 21:17:09 UTC (almost 13 years ago)
I'm using Gimp 2.6.12 on Ubuntu 12.04 (with Xfce desktop).
Recently, I noticed that at least 2 features suddenly don't work (I say "at least" because there might be more that I'm just not aware of). These features are rotating a layer and making a drop shadow.
The only thing I can think of that's changed is that I moved some brushes around (added a few to the Brushes folder and took a few out that were in there).
I use these features all the time and I want to know what to do to get them back.
FYI, the version of Gimp I'm using is the one that's available in the Ubuntu Software Center. I'm not experienced enough with Linux to install the most recent update.
2012-06-30 21:54:31 UTC (almost 13 years ago)
And would you like to tell us what exactly happens whe you try to use those features? And how you use them?
2012-07-01 02:28:48 UTC (almost 13 years ago)
I use them the way I've always used them, by selecting the layer and -- for the rotate, selecting the rotate tool in the toolbar and clicking, then either using the slider or changing the angle value. For drop shadow, selecting that option from the Filters menu and putting in the values in the dialog box.
For each of them, now, what happens is -- nothing. The layer is exactly the same -- not rotated, no shadow, nothing happens. No error message, no change, nothing.
To clarify, I'm trying to apply each separately, not at the same time. It just seems to have happened suddenly that both no longer work.
2012-07-02 19:27:32 UTC (almost 13 years ago)
Could you please check if other transformation tools such a perspective work? Any other scripts, e.g. Xach-effect from the same submenu?
