GIMP 2.8 per Windows, problem with the color picker
13 of 13 messages available
GIMP 2.8 per Windows, problem with the color picker Kekko 02 Jun 13:56
  GIMP 2.8 per Windows, problem with the color picker Richard Gitschlag 02 Jun 14:46
   GIMP 2.8 per Windows, problem with the color picker Kekko 02 Jun 15:09
    GIMP 2.8 per Windows, problem with the color picker Richard Gitschlag 02 Jun 16:10
     GIMP 2.8 per Windows, problem with the color picker Noel Stoutenburg 04 Jun 16:33
      GIMP 2.8 per Windows, problem with the color picker TracyF 16 Jun 14:15
       GIMP 2.8 per Windows, problem with the color picker Camo 31 Aug 15:29
        GIMP 2.8 per Windows, problem with the color picker Alexandre Prokoudine 31 Aug 15:41
         GIMP 2.8 per Windows, problem with the color picker Camo 31 Aug 16:01
       GIMP 2.8 per Windows, problem with the color picker Nik Omul 31 Aug 16:18
        GIMP 2.8 per Windows, problem with the color picker stAn99 28 Apr 16:42
         GIMP 2.8 per Windows, problem with the color picker Maxeem 28 Jul 16:55
          GIMP 2.8 per Windows, problem with the color picker Michael Schumacher 28 Jul 17:35
2012-06-02 13:56:55 UTC (almost 13 years ago)
Did you note that in the 2.8 version for Windows the color picker does not properly run? It picks only black and no other colors.
Richard Gitschlag
2012-06-02 14:46:00 UTC (almost 13 years ago)
Date: Sat, 2 Jun 2012 15:56:55 +0200 From: forums@gimpusers.com
To: gimp-user-list@gnome.org
CC: team@gimpusers.com
Subject: [Gimp-user] GIMP 2.8 per Windows, problem with the color picker
Kekko (via gimpusers.com)
Never experienced any colorpicker problems on my Windows GIMP ... ever. Can you be more specific?
While using the colorpicker, hold Shift to display the pixel info dialog. The left column should list "Red/Green/Blue" values. If it only lists "Value", this is because you're not actually selecting from the layer:
1 - If you're currently editing a layer mask, then the colorpicker will only return a grayscale "Value", because layer masks are a grayscale channel. 2 - Same goes for if you have QuickMask active, because then it's picking from the selection channel.
2012-06-02 15:09:14 UTC (almost 13 years ago)
Sorry to be not very clear. I'm referring to the eyedropper in the "Foreground change color" and the issue is present also if I click the eyedropper in the one-only layer picture. Try it. Thanks
Bye
Francesco
Richard Gitschlag
2012-06-02 16:10:10 UTC (almost 13 years ago)
Date: Sat, 2 Jun 2012 17:09:14 +0200 From: forums@gimpusers.com
Bye
Francesco
You mean holding down Ctrl with a paint tool to activate colorpicker mode? Tried that and worked perfectly - unable to reproduce the described behavior.
In a single layer image with no transparency, always picked the pixel's color value.
In a multi-layer image with or without transparency, always picked the pixel value from the active layer only, it had no effect (retained previous picked color) outside the active layer area. Found no apparent way to make the colorpick modifier (as opposed to the colorpicker tool) sample from all layers.
Another very important note: Transparent pixels within a layer still retain their original color value. If, for example, you paint a HSV spectrum onto a layer and then erase it to transparency, the colorpicker will still pick the color pixels from it. Which brings to mind that the default "color" for a transparent area is black.
Noel Stoutenburg
2012-06-04 16:33:30 UTC (almost 13 years ago)
I suspect that Francesco had the same problem I did. In the color picker dialog box, there is an icon, about 2/3 of the way from the top, which when one hovers the mouse cursor over the icon, reveals the context help that one can select a color from anywhere in the screen. When one's cursor is located over a GIMP window, this is true, one can select a color; when the cursor is over a part of the screen that is not part of a GIMP window, the cursor reverts from the eyedropper shape to the normal cursor shape, and in my experience, one was not able to select a color from any part of the screen that was not a GIMP related window.
This is a known gtk+ issue in windows (bug 653653) at bugzilla.gnome.org.
ns
2012-06-16 14:15:03 UTC (almost 13 years ago)
Yes, this is the problem I'm having as well. It's definitely a bug.
2012-08-31 15:29:15 UTC (over 12 years ago)
This is the last answer?! And now what? Nobody interest about it? This make Gimp totaly unusebly. What can we do?
2012-08-31 15:41:42 UTC (over 12 years ago)
Apart from checking, whether 2.8.2 still has it, and then telling us? Well, praying on knees seems to be popular :)
2012-08-31 16:01:02 UTC (over 12 years ago)
I downlod newest Gimp today. And I used to change the fg color in color dialog. Today I foud out that color picker tool exist. So it works(hope). But it is the right that eyedropper doesn´t work. Like in "color to alpha" dialog in 2.6 version.
So execuse me my histerical reaction....
PS: I think that the resize tool is much slower as in 2.6 version.
Nik Omul
2012-08-31 16:18:19 UTC (over 12 years ago)
Select Color picker tool and in Tool Options dockable dialogue toggle Set_foreground_color instead of Pick_only. Now when you use eyedropper from Change_Foreground_Color dialog window it will change foreground color to the one you picked. This will help you restore your workflow til the bug is fixed.
-- TracyF (via gimpusers.com)
gimp-user-list@
Nik O.
Никита Омуль
View this message in context: http://gimp.1065349.n5.nabble.com/GIMP-2-8-per-Windows-problem-with-the-color-picker-tp14083p35282.html Sent from the Users mailing list archive at Nabble.com.
2014-04-28 16:42:07 UTC (almost 11 years ago)
Hello friends, it's 2014 and i just updated gimp to 2.8.10 from 2.8.2 and am still getting issue with ALL COLOR PICKERS linked from any of the dialogs. The color picker always returns black color regarless of where you click. I am on RDP, Win7 x64 Slovak. This really makes Gimp useless.
Maxeem
2014-07-28 16:55:56 UTC (over 10 years ago)
The very basic GUI color picker works well when somewhat inconveniently switching from my present tool to the color picker tool. Hotkeys sort of solve this.
Thankfully, holding down 'Control' (in Windows/Linux) results in the color picker temporarily popping up before reverting to present tool upon release of the key.
But one of the absolute best ways to pick color has been clicking on the present colors to get the color dialogue, so you can work with the pallet and get any visible on-screen color, which is one of the most amazing and useful tools built into 2.6 that *is lost* in 2.8, according to some. Like DSunhammer, I have the same bug — where (I guess) someone simply forgot to change the present selection to the color detected. It just makes the present selection pure black #000000. So close to being useful!
Otherwise, pretty great work on the new version in all other aspects, and I look forward to the next version where hopefully our great in-dialog color picker returns! (Any chance for a patch?)
-- View this message in context: http://gimp.1065349.n5.nabble.com/GIMP-2-8-per-Windows-problem-with-the-color-picker-tp14083p43256.html Sent from the Users mailing list archive at Nabble.com.
2014-07-28 17:35:18 UTC (over 10 years ago)
Could be bug https://bugzilla.gnome.org/show_bug.cgi?id=676708, depending on your platform (it as been reported for and confirmed on Windows XP). There's also some other bug report with this symptom in the bug tracker.
If it is that bug, then there's a patch attached to it - to cairo. Not sure if the cairo developers have applied it yet.
