a question about drwaing circles!
a question about drwaing circles! Mehrdad 16 May 10:27
  a question about drwaing circles! Alexandre Prokoudine 16 May 11:41
   a question about drwaing circles! Mehrdad 16 May 12:43
    a question about drwaing circles! Alexandre Prokoudine 16 May 12:52
2012-05-16 10:27:39 UTC (almost 13 years ago)
i have a question, imaging im in terrible hurry to draw an empty circle around a text and go on for others, whats the fastest way???
something like this: http://up.vatandownload.com/images/vgv2kprqm8bckk6yfhy.jpg
i already know some ways, for example: using "Border" (in Select menu) or "Stroke Selection" (in Edit menu) i want the "fastest way", those two ways need too many delays.
my teacher read the book fast and i should draw as fast as him.
thank you all in advance
2012-05-16 11:41:34 UTC (almost 13 years ago)
That sounds like sketching to me. Why not just use the brush or the pencil tool?
2012-05-16 12:43:35 UTC (almost 13 years ago)
you mean using brush (or pencil) is the last chance??? no other way?
thanks for your attention Alexandre
2012-05-16 12:52:27 UTC (almost 13 years ago)
There is no faster way to do that in GIMP currently. You can set a shortcut to the menu command that activates selection stroking, but you still have to confirm stroking settings.
Alternatively, you could use Inkscape that has a nice text tool and easy drawing of geometric shapes.
It really depends on a few factors like whether the circles should be pretty or geometrically correct. If you only need those circles around text for yourself, brush/pencil could do the work.
