Gimp 2.8 - Default Toolbox on the right
Gimp 2.8 - Default Toolbox on the right utiler 10 May 02:31
  Gimp 2.8 - Default Toolbox on the right Alexandre Prokoudine 10 May 07:42
   Gimp 2.8 - Default Toolbox on the right utiler 17 May 11:26
2012-05-10 02:31:21 UTC (almost 13 years ago)
Hi everybody,
I have just loaded 2.8 with much anticipation and found that the default toolbox is fixed on the right-hand side of the screen adjacent to the dockable toolbars.
Is this normal for 2.8? It seems weird that it would now be positioned on the right....
Thank you, Andrew
2012-05-10 07:42:36 UTC (almost 13 years ago)
On Thu, May 10, 2012 at 6:31 AM, utiler wrote:
Hi everybody,
There's nothing weird. You moved it to the right from the main window while it was a floating window, and now it's docked there.
Disable single-window mode, move toolbox to the left of the main window, enable SWM again.
2012-05-17 11:26:54 UTC (almost 13 years ago)
Hi everybody,
Thank you Alexandre, such a simple fix!!!!!
