Strange thins with GIMP 2.0 and SVG
Strange thins with GIMP 2.0 and SVG Milen Dzhumerov 25 May 15:18
  Strange thins with GIMP 2.0 and SVG Sven Neumann 25 May 15:03
   Strange thins with GIMP 2.0 and SVG Jean-Luc Coulon (f5ibh) 25 May 16:59
    Strange thins with GIMP 2.0 and SVG Sven Neumann 25 May 18:22
   Strange thins with GIMP 2.0 and SVG Jakub Steiner 27 May 19:57
2004-05-25 15:03:53 UTC (almost 21 years ago)
Milen Dzhumerov writes:
I am experiencing some strange things with GIMP 2.0.Yesterday when I worked with svg icons everything was fine.But today if I open the svg it is shifted to the right and down corner and it isn't okay.I open the svg and then export it to gif to use it for a web site.To illustrate better the problem here are the screens:
Preview OK - http://www.openclub-bg.org/gg_ok.png
Who created that preview? The GIMP file open dialog only shows the thumbnail, it doesn't necessarily create it also.
Open Bad - http://www.openclub-bg.org/gg_bad1.png Opened - http://www.openclub-bg.org/gg_bad2.png
What would really be interesting is a pointer to the SVG file. This could indeed be a bug in librsvg (which is what GIMP uses to render the SVG) but it is more likely that this SVG file simply has a wrong bounding box.
Milen Dzhumerov
2004-05-25 15:18:00 UTC (almost 21 years ago)
Hello people,
Preview OK - http://www.openclub-bg.org/gg_ok.png Open Bad - http://www.openclub-bg.org/gg_bad1.png Opened - http://www.openclub-bg.org/gg_bad2.png
Thanks
Milen Dzhumerov
2004-05-25 15:18:01 UTC (almost 21 years ago)
Hello people,
Thanks
2004-05-25 16:59:12 UTC (almost 21 years ago)
I
svg it
the
svg
better
the problem here are the screens: Preview OK - http://www.openclub-bg.org/gg_ok.png
There are some problems with the librsvg and Debian sid just after the upgrade of gtk+ to 2.4 2 days ago. It is needed to get librsvg from "experimental" to have the svg icons of the desktop themes displayed. Maybe it is related ?
see bug:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=250647&archive=no&mbox=no
-- - Jean-Luc
2004-05-25 18:22:26 UTC (almost 21 years ago)
"Jean-Luc Coulon (f5ibh)" writes:
There are some problems with the librsvg and Debian sid just after the upgrade of gtk+ to 2.4 2 days ago. It is needed to get librsvg from "experimental" to have the svg icons of the desktop themes displayed. Maybe it is related?
No, that's certainly unrelated. The problem here is simply that the SVG pixbuf loader module needs to be recompiled against gtk+-2.4.
Jakub Steiner
2004-05-27 19:57:31 UTC (almost 21 years ago)
I filed this as http://bugzilla.gnome.org/show_bug.cgi?id=143300 since librsvg's rsvg utility seems to have no problem with it.
cheers
