How to control one color only?
How to control one color only? Keith Purtell 11 Apr 16:46
  How to control one color only? Steve Kinney 11 Apr 17:17
  How to control one color only? Борис Кукушкин 11 Apr 21:52
How to control one color only? Judah Kleinveldt 12 Apr 16:35
  How to control one color only? Keith Purtell 12 Apr 16:37
Keith Purtell
2012-04-11 16:46:54 UTC (about 13 years ago)
This is another of those things I knew how to do in PShop and am now trying to duplicate in GIMP. I have a photo of a flowchart drawn in green marker on a whiteboard. Photo taken with an iPhone, so quality is yuck. I brought out the greens with Color Enhance, but now the white board has areas that are yellow on the right and blue on the left.
How to target these "problem colors" and desaturate or otherwise move them back to white?
Keith
2012-04-11 17:17:07 UTC (about 13 years ago)
Hey Keith,
The Select By Color tool might do the trick for you - it's a button in the top row of the (default) main toolbox. Turn it on, click in an "average looking" part of the unwanted color anywhere in the image, and see how close it comes to getting everything you want to alter. In the Tool Options dialog dock, you can adjust the threshold of this tool to select a wider or narrower range of colors, image-wide.
Once you have (only) the bits you want to change selected, you can do any of a number of things: Drag and drop your color of choice from the foreground/background tool, use the Colors > Hue/Saturation tool, or etc.
:o)
Steve
Борис Кукушкин
2012-04-11 21:52:27 UTC (about 13 years ago)
Good day, Keith!
Could you show an example? For some reason I have a feeling that there is more than one way to accomplish this.
Best regards, Boris
2012/4/11 Keith Purtell
Keith
gimp-user-list@gnome.org
Judah Kleinveldt
2012-04-12 16:35:42 UTC (about 13 years ago)
[Gimp-user] How to control one color only? Message-ID:
Content-Type: text/plain; charset="utf-8"
Keith the way I'd do it to keep things simple and quick is to create a selection of the troubling area, begin by creating a duplicate layer first then select (on the duplicate) as close the pixels as possible the area you need, create a new path from this selection incase you need to reselect later on.
Select area can then be adjust to what ever you need. Saturation, hue, contrast or even bluring.
To blend the changes to the rest of the image pixels a slight blur using the blur tool work well for me, starting with the slightest of opacity and blur. Ctrl+Z is my friend in this case.
Hope it helps you :)
Keith Purtell
2012-04-12 16:37:02 UTC (about 13 years ago)
That's an approach I've never tried. Looking forward to seeing the results!
Keith
