Why does saves as JPG default to quality 85?
I've noticed that every time I save an image in GIMP as JPG the quality slider bar defaults to 85. Even though I keep changing it to 75. If this numeric value is a Photoshop equivalent like other GIMP features, then 85 is probably a wasted effort. The research* I'm aware of* (note emphasis) says that the quality in JPG images saved at a level above 75 is "theoretical." In other words, the increased quality is there in technical terms, but imperceptible to the human eye. Comments?
Keith
i don't get 85% as default every time. in my observation, the default changes with the image, i.e., lots of detail or lots of same or similar colors, etc.
when i prepare a jpg for the web, i go down with the quality until i see a real difference at 100% zoom; often that's only a fraction of the default setting. on the other hand, if the jpg is intended for printing by someone, i usually leave the default, which often is above 90% with my images.
That's odd. Every version of the GIMP I have ever used defaulted to the legacy Photoshop value of "75" for JPG save quality. I usually use 85%. Prompted by your comments I went looking through the config files of my local installation and did not find a variable that I could tweak to change the default from 75 5o 85.
If this numeric value is a Photoshop equivalent like other GIMP features, then 85 is probably a wasted effort. The research*I'm aware of* (note emphasis) says that the quality in JPG images saved at a level above 75 is "theoretical." In other words, the increased quality is there in technical terms, but imperceptible to the human eye. Comments?
The compression artifacts in JPG images saved at quality 100 are usually not visible in images viewed at 1:1 scale. At 50, they are usually very obvious. Between these values, a lot depends on the content of the image. A cloudscape or misty forest scene may look OK at lower values, but an image with lots of strong, adjacent contrasts eg sharp edges, shows lots of visible artifacts at higher compression rates. Over the years I have settled on 85 as my own preferred compression setting for most JPG images.
Lossy compression is a trade off between resolution and file size. Like the default 75 DPI resolution GIMP inherits from Photoshop, the JPG quality setting of 75 is a legacy of obsolete technology - 75 DPI monitors hooked to computers with dial up network connections and 500 MB hard drives. Today the vast majority of monitors have 96 DPI resolution, nearly all network connections are at least 128 kbps, and it's hard to buy a hard drive with less than 100 GB of storage. To me it makes sense to adjust media files that live in this environment accordingly.
75 DPI resolution is "only a suggestion" and does not degrade an image, but lower JPG quality settings do make a real difference. Information is lost and artifacts are introduced. In many instances the difference between JPG quality of 75 and 85 is visible on modern monitors. The savings in file size between JPG quality of 85 and 75 is not large enough, IMO, to justify the small but visible loss of resolution. YMMV and lots of people are perfectly happy with the default setting of 75 for web images.
:o)
Steve
The quality rate of JPEG is not a percentage, simply a rate between 0 and 100.
To my knowledge, the suggested quality rate is a part of the photograph. My camera suggests 90, my daughter's camera suggests 93, and I always decrease it to 85, or export to PNG.
Olivier Lecarme
A number in the range 0 to 100 is actually by definition a percentage ;-)
GIMP tries to detect the compression that was used for the original image and uses those settings if they're known.
The GIMP numbers are *not* the same as for PhotoShop - 75% in gimp is not the same as 75% in photoshop.
I get 97% suggested with my Canon EOS camera.
You should always save to a lossless format such as PNG if you might need to work on the image again in the future - every time you load and save a JPEG file the quality is reduced and information is lost.
Liam
Liam
Liam Quin - XML Activity Lead, W3C, http://www.w3.org/People/Quin/ Pictures from old books: http://fromoldbooks.org/
2012/3/23 Liam R E Quin :
That's a weird definition of a percentage!
Considering the quality rating in JPEG as a percentage would mean that a quality equal to 100 would be perfect, i.e. no loss at all. Unfortunately, 100 means "very good", and 90 means "very good" too. None of them is perfect, and the size of the file increases much faster than the quality. This explains why many people recommend 85, which is a good compromise.
Olivier Lecarme
Nonsense. A "quality" of 100% means you have chosen 100 out of a possible 100. "per cent" means "out of 100" in Latin. It says nothing about secondary values. A value of 75% means 75% of the way from 0 to the maximum allowed value of 100. I agree that popular usage is to infer more than is stated from such an assertion. Note that in general (but not in this case) percentages can be greater than 100.
Yes, many people recommend 85% but 85% in gimp (or 85, if you prefer) is not at all the same as 85% in PhotoShop.
Maybe it would be less confusing to make the numbers go from 0 to 255 or something. Then 255 would be 100% of the allowed value.
Best,
Liam
I suppose the reason I didn't go the preview route is that I'm a bit annoyed that GIMP doesn't remember that I've changed that setting to 75 every single time I've made a JPG. Now that you suggest it, I could run a test and see if GIMP's apparent 85 default really does/doesn't make a significant difference in file size compared to the number I prefer. If the two yield similar results, I can just accept the fact that GIMP won't adapt to a user's work pattern (grrrr, don't like that idea) and let it save all JPG files at 85.
Keith
(PS Cool sig)
On Fri, Mar 23, 2012 at 4:34 PM, Johnny Rosenberg wrote:
Why not just look at the preview yourself and make your own opinion?
My experience is that at high numbers (maybe 90 and above, depends on the image), every little change means a big change in file size but a little visible change in the image. On the other hand, at low numbers, say 50 or lower, this also depends on the image, every little change means a big change in image quality but only a little change in file size. Just fiddle with the numbers yourself, looking at the preview at a reasonable zoom level, and you will get close to the optimal compromise between file size and image quality.
Kind regards
Johnny Rosenberg ジョニー・ローゼンバーグ
I can hear the wailing and gnashing of users now: "I followed the tutorial exactly and saved the final JPEG at 85 quality but now it looks terrible!!!1!" ;)
And then the brains exploding when explaining that 85 is 33% of 255.
Chris
Keith
On GIMP 2.6.10 on Windows, I see two buttons near the bottom of the dialogue where the JPEG quality is set - "Load Defaults" and "Save Defaults". If I set the quality to 75% and click "Save Defaults", that comes up as the default next time I go to save a new JPEG. If working on an existing file, the dialogue initially shows the settings used when that file was last saved, but clicking "Load Defaults" quickly restores the saved default settings (75%). Those buttons presumably save and restore the "Advanced Options" as well, but I haven't looked in that much detail.
Mark.
Maybe this manual entry would help.
http://docs.gimp.org/2.8/en/gimp-images-out.html#gimp-using-fileformats-export-dialog
-- Owen
Not true... if nothing changes the algorithm is stable (decoded values get re-encoded to the same values). You lose quality if you recompute something different; changed settings, changed pixel values, changed 8x8 boundaries (image crop).
* Ofnuts [01-01-70 12:34]:
save a JPEG file the quality is reduced and information is lost.Not true... if nothing changes the algorithm is stable (decoded values get re-encoded to the same values). You lose quality if you recompute something different; changed settings, changed pixel values, changed 8x8 boundaries (image crop).
Well, it is true and very easily proven.
Open a jpg file and save it. Then open the just saved file and save it again at the save compression level. Then do a diff or simply check the file sizes.
I wrote this Perl script a while ago:
-------------------------- # Runs successive JPEG saves on an image to evaluate JPEG losses # Author: Ofnuts
$dotradius=2;
$defaultsteps=10;
$defaultquality=92; # default quality for "convert"
$steps=$defaultsteps;
$quality=$defaultquality;
$dotcolor="white\n"; # change this if the top of the image is too clear
$argc=@ARGV;
usage() if ($argc > 2);
if ($argc>1)
$steps=$ARGV[1];
usage() if ($steps!~/^\d{1,3}$/);
if ($argc>0)
$quality=$ARGV[0];
usage() if ($quality!~/^(\d{1,2}|100)$/);
print "Running $steps steps at JPEG quality $quality\n";
for ($step=0;$step by default.
-- Unless reproduced by different means, these results only apply when the same software is used throughout.
My step000.jpg is here: http://i.imgur.com/iWwXP.jpg
Interesting. Not 100% true - I made a sample image and saved it at 75% (OK, 75 if you prefer) in gimp, then opened the jpeg and saved it again, and reopened that; the 1st and 2nd generation files do have visible differences, but the differences are massively smaller than those between the original and the 1st generation image. The visible differences were extra "fringes" around the jpeg-introduced fringes. I've appended the (totally not scientifically constructed) sample image I used.
You are right that the changes seem to get smaller each time.
In practice, however, someone opening the file and doing changes may very well do global changes (e.g. unsharp, sharpen, curves) that accentuate the jpeg artifacts; I still think it better to save as PNG (or xcf.gz) until you're finished.
Thank you for the script.
Liam
A percentage is a way of expressing a ratio. 20% means the same as 20/100 or 1/5. It's used to express how large/small one quantity is, relative to another quantity. Here, what is the other quantity?
In degrees centigrade, the temperature of liquid water ranges from 0 to 100. Does that mean that water at a temperature of 30 degrees is 30%? 30% of what?
Notice that most descriptions of the quality factor of JPEG carefully avoid speaking of percentages. See for example http://docs.gimp.org/2.8/en/gimp-images-out.html#idp11992944 or http://en.wikipedia.org/wiki/JPEG.
