Short cut [ and ]
Short cut [ and ] TheoN 18 Feb 13:29
  Short cut [ and ] Steve Kinney 18 Feb 14:12
   Short cut [ and ] TheoN 18 Feb 15:35
    Short cut [ and ] Johnny Rosenberg 18 Feb 15:39
     Short cut [ and ] TheoN 18 Feb 15:59
2012-02-18 13:29:15 UTC (about 13 years ago)
Short cut [ and ]
Dear developers,
There is short cut missing in the new version 6.2.12 In version 2.6.11 you can change the scale of brushes by using ] to enlarge or [ decrease the size of the brush. It would be nice if this came back in the next version therefore I turn back to version 6.2.11. It's a very handy tool.
However I look forward to the new version 2.8 the developers did a very good job. The link http://libregraphicsworld.org/blog/entry/what-hasnt-happened-to-gimp-2.8 impressed me for the new appications. Many thanks for this.
Regards Theo
2012-02-18 14:12:07 UTC (about 13 years ago)
Short cut [ and ]
On 02/18/2012 08:29 AM, TheoN wrote:
Dear developers,
Hey Theo,
I don't know if this is relevant to your use case, but one of my favorite "should be a default" features is the ability to use the normally unassigned alt + mouse wheel combination to scale brushes. Since [ and ] are usually right-handed gestures, most users will like not having to let go of their mouse to change their brush size. Configuration, illustrated:
http://pilobilus.net/img/mouse-scale-brush.jpg
:o)
Steve
2012-02-18 15:35:26 UTC (about 13 years ago)
Short cut [ and ]
Dear developers,
Hey Theo,
:o)
Steve
Thanks a lot Steve,
I have installed the version 6.2.12 again installed over the previous version and now the short key [ and ] does work again. I don't know the reason for this, but every thing it’s OK now. The illustration of the mouse in combination is a different content in my Dutch version, but I see this can be modified. It's very useful.
Best regards Theo
Johnny Rosenberg
2012-02-18 15:39:05 UTC (about 13 years ago)
Short cut [ and ]
2012/2/18 TheoN :
Dear developers,
Hey Theo,
:o)
Steve
Thanks a lot Steve,
I suppose you mean 2.6.12, right?
Kind regards
Johnny Rosenberg ジョニー・ローゼンバーグ
Best regards Theo
TheoN (via gimpusers.com)
gimp-user-list@gnome.org
2012-02-18 15:59:11 UTC (about 13 years ago)
Short cut [ and ]
2012/2/18 TheoN :
Dear developers,
Hey Theo,
:o)
Steve
Thanks a lot Steve,
Kind regards
Johnny Rosenberg
ジョニー・ローゼンバーグ
Yes Johnny version 2.6.12 is right and the short key [] works fine. Problem solved.
Regards Theo
Best regards Theo
