Using Gimp commercially- help needed
Using Gimp commercially- help needed Richard Allport 07 Feb 11:59
  Using Gimp commercially- help needed Alexandre Prokoudine 07 Feb 12:24
Using Gimp commercially- help needed Kevin Brubeck Unhammer 07 Feb 12:51
Richard Allport
2012-02-07 11:59:07 UTC (about 13 years ago)
Hi all, does anyone know if there is a clearance procedure someone would have to go through in order to use Gimp in a commercial, sale –based product teaching creativity or other visual based subjects? Or someone I could email or call directly failing that?
Best
Richard Allport
Specialist Creative Training for Education and Business www.easyartpro.com
0771 0500 891
2012-02-07 12:24:31 UTC (about 13 years ago)
2012-02-07 12:51:00 UTC (about 13 years ago)
Alexandre Prokoudine writes:
You are encouraged to make money using GIMP.
… but in case you don't want to take legal advice from random strangers, gimp.org itself is quite clear on this:
http://www.gimp.org/about/selling.html
See also the license itself – which most likely zoomed past your eyes as you installed GIMP – for the legalese: http://www.gimp.org/about/COPYING , e.g. the second paragraph of the Preamble.
Hope this helps, good luck on your product :)
