Exporting high-quality PNG w/transparency?
Exporting high-quality PNG w/transparency? Keith Purtell 28 Jan 21:58
  Exporting high-quality PNG w/transparency? Chris Mohler 28 Jan 22:39
  Exporting high-quality PNG w/transparency? Liam R E Quin 29 Jan 00:02
   Exporting high-quality PNG w/transparency? Keith Purtell 29 Jan 01:10
Keith Purtell
2012-01-28 21:58:28 UTC (about 13 years ago)
Several times a week I need to take a PDF (single-page doc), then convert to a page-sized PNG with quality good enough to read the text (and a transparent border), and then convert to a SWF. I have a PNG-to-SWF utility, but when I used it on the PNG saved after I opened my PDF and exported from GIMP, the end result was not good enough. A co-worker said GIMP couldn't make a PNG (w/transparency) with enough quality. He said we'd have to use some other software. Part of the issue was not being able to resize without losing quality before the PNG export. True or false?
Keith
Chris Mohler
2012-01-28 22:39:20 UTC (about 13 years ago)
False. As long as the PDF has sufficient resolution (or is vector), and you select a high enough resolution setting when importing the PDF into GIMP, you shouldn't have quality issues.
Chris
Liam R E Quin
2012-01-29 00:02:05 UTC (about 13 years ago)
On Sat, 2012-01-28 at 15:58 -0600, Keith Purtell wrote:
It may be true that your co-worker said that . :-)
But there's some confusion here.
PNG is a lossless format, so the quality is always 100% On the other hand, scaling an image *is* lossy. Enlarging an image introduces errors where the software inventes the extra detail. Shrinking an image throws away detail, and it's easy to lose serifs, punctuation, the cross-bars of H and e, and so forth, or to weaken them.
A method that may help for rescaling text: (1) open the PDF at 3 times final resolution (2) use filter->distorts-Value Propagate, with 'more black' and an amount of about 0.25 or 0.33; this will strengthen the weaker parts of the letters.
(3) use filters->gaussian blur, radius 3 (you can experiment, radius 5 may work better)
(4) scale the image to 33.33%
(5) use colours->curves and make an S-shaped curve, so that the curve goes below the diagona lline on the bottom left, then emerges slightly to the left of centre, and is then above the diagonal. Or for a sharper look, just drag the two endpoints of the diagona lline in slightly towards the middle, e.g. by 1.5 squares on the dialogue grid.
Having said that, you'll likely get even better results using pstoedit to generate wmf fro pdf directly. PDF and WMF are both vector formats, and you can resize a vector image without loss of quality. PNG is a bitmap image, and cannot so easily be resized.
Liam
Keith Purtell
2012-01-29 01:10:20 UTC (about 13 years ago)
Outstanding! That not only gives me immediately useful answers, but I'm looking into pstoedit and Ghostedit as tools.
Keith
