Help with batch processing
Help with batch processing Pablo Gustavo Rodriguez 04 Aug 00:04
  Help with batch processing Ofnuts 04 Aug 00:51
   Help with batch processing rich 04 Aug 09:20
   Help with batch processing Maurice 08 Aug 11:29
  Help with batch processing Victor Sanchez2 08 Aug 11:55
2011-08-04 00:04:27 UTC (almost 14 years ago)
Hi everybody:
I use Gimp just for personal pursposes like improving the colour of my photos, and I have a question that I couldn´t answer by myself so far. I use to take the same steps with every picture when improving the colour: I go to menu Colors / Levels, press the button Auto, then OK, Save and Close file. I have 200 photos taken in a tour and I´m looking for a way to do this in a batch mode, for all files at once, maybe from command line, but I couldn´t find how in the online user manual. It seems to me that script-fu may be useful but the manual didn´t help me. Is there a way to do waht I want to do?. Can any body tell me which is the function or recommend me a tutorial?.
I run Gimp 2.6 under Windows 7-64 bits Very much thanks in advance.
Pablo
Lic. en Antropología
http://www.analisiscualitativo.com.ar/
Gimp-user mailing list
2011-08-04 00:51:42 UTC (almost 14 years ago)
On 08/04/2011 02:04 AM, Pablo Gustavo Rodriguez wrote:
Hi everybody:
Some people will likely give a very documented answer for Gimp batch. But
1) there is also an auto-level in ImageMagick convert (www.imagemagick.org) that will likely be both faster and easier to use from the command line:
see http://www.imagemagick.org/script/command-line-options.php#auto-level for more similar options
2) if you have to run this on all/most pictures you take, you should investigate changing the settings on your camera.
rich
2011-08-04 09:20:34 UTC (almost 14 years ago)
Hi everybody:
Davids Batch processor. Gimp Plugin
http://members.ozemail.com.au/~hodsond/dbp.html
In the colour section there is a tick box for auto-levels
Maurice
2011-08-08 11:29:06 UTC (almost 14 years ago)
On 2011-08-04 at 01:51 Ofnuts said:
I had to replace "--auto-level" by "-auto-level" to do that!
Victor Sanchez2
2011-08-08 11:55:16 UTC (almost 14 years ago)
Hi Pablo,
you can use Script-Fu, more specifically 'gimp-levels-stretch':
"This procedure allows intensity levels in the specified drawable to be remapped according to a set of guessed parameters. It is equivalent to clicking the "Auto" button in the Levels tool. This procedure is only valid on RGB color and grayscale images. It will not operate on indexed drawables."
You can access it in Gimp from Filters -> Script-Fu -> Console.
Some time ago, I published a manual about a similar procedure to round-corners. You can consult in:
www.victorsanchez2.com/#GimpScript-FU-1 www.victorsanchez2.com/#GimpScript-FU-2
and ask me if you want.
Here you can get the script directly:
http://www.victorsanchez2.com/fotolibre/round-corners-fotolibre-png.scm
Regards, Víctor.
On 4 August 2011 02:04, Pablo Gustavo Rodriguez wrote:
Hi everybody:
Pablo
-- ************************************************* Pablo Gustavo Rodriguez
http://www.analisiscualitativo.com.ar/ *************************************************
VictorSanchez2
victorsanchez2 en jabberes.org
