Text Won't Enlarge Past 30 PX
Text Won't Enlarge Past 30 PX Andrew Hall 27 Feb 16:56
  Text Won't Enlarge Past 30 PX Burnie West 27 Feb 18:16
  Text Won't Enlarge Past 30 PX Leonard Evens 27 Feb 18:31
Andrew Hall
2011-02-27 16:56:34 UTC (over 14 years ago)
I am a new Gimp user and have just started working on my first project with this application. Unfortunately, I ran into a roadblock almost immediately. I am unable to make text any larger than 30 PX. I can enter larger sizes than this in the Text Tool window, but any value greater than 30 has no effect. It doesn't matter whether I am trying to change existing text or am setting up the Text Tool for entering some new text. Selecting different units for the text size makes no difference in the maximum text size.
Any ideas?
Best regards, Andy Hall
Gimp 2.6.11
Mac OS 10.4.11
Burnie West
2011-02-27 18:16:59 UTC (over 14 years ago)
Any ideas?
Are you using a scalable font?
Leonard Evens
2011-02-27 18:31:04 UTC (over 14 years ago)
I don't have any trouble making text as large as I might want. However, if I make it too large to fit in the image frame, it gets truncated. When you use the text tool, it produces a small window in which you enter the text, and it is then that you vary the font and size. Also, if I want to modify the size later, all I have to do is make sure I choose the layer containing the text. Look at the layers window. If you are making multiple attempts to create text, you may end up making more than one text layer, and in that case, you should make sure you've selected the one you want to change.
Any ideas?
Best regards,
Andy Hall
Gimp 2.6.11
Mac OS 10.4.11
