Help installation, 2.6.1-html-en.tar.bz2
Help installation, 2.6.1-html-en.tar.bz2 Doug Huffman 07 Feb 13:20
  Help installation, 2.6.1-html-en.tar.bz2 rich 07 Feb 17:47
   Help installation, 2.6.1-html-en.tar.bz2 Doug Huffman 08 Feb 22:26
    Help installation, 2.6.1-html-en.tar.bz2 rich 09 Feb 08:59
    Help installation, 2.6.1-html-en.tar.bz2 rich 09 Feb 09:00
  Help installation, 2.6.1-html-en.tar.bz2 Sven Neumann 08 Feb 20:08
Doug Huffman
2011-02-07 13:20:11 UTC (almost 14 years ago)
Where does html/en need to be installed in GIMP file structure, please? -----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.14 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJNT/GLAAoJEIpOLnult3mgLTgH/2AAgP0XhyQQZBVxRwRjZHny 9myd5hUT94WwqHs38L08c0HdfaV2IpSSat+crykaYu2f3irY7qU/2L68Kk+1oqRG 07J+yFY9FgKToVIzOFKajmz1RV2ResZioNLj4tWqdw+p2AgpNMHF1aU5wu/TT1Nz dsWjknLQiwXh+CWdwS5bg/4T7NapA3qSjBAIOOsjApb62nBnA5ragAIJqUo6FxSH KvkjEHwyt8dO+So4iNMEtvdQ3BwT0JH8NLPa44tSzqrvLzhfTX7P8GhouK6Wf8Ec vnikh31/NC/CFDzlAjWQ7F+GRCAKvVmMFaP7/7AivUCrMayeMupLGtIDQvKEha0= =+ZsA
-----END PGP SIGNATURE-----
rich
2011-02-07 17:47:40 UTC (almost 14 years ago)
snip
Gimp 2.6 help files, a bit of a PITA.
unpack the archive (I use peazip) and eventually you get down to a folder
/gimp-help-2/html/en/ which contains a whole load of files and an /images folder
this goes in /usr/share/gimp/2.0/help/
big *but* if you want to call the help files from gimp 2.6.x it probably will not work.
What I have found to work is:
Install the gimp 2.4 help package from your repo. Check that it works.
Copy all the archive "en" files & the /images to the /usr/share/gimp/2.0/help/en directory overwriting anything of the same name. You end up with a few surplus files but not that many and help (F1) called from gimp works.
I hope someone has a better solution. Just broke my installation messing around and to reinstall gimp 2.4 help, then the new files so here is a screen shot.
http://www.imageno.com/fh1pn2dlnu2apic.html
2011-02-08 20:08:08 UTC (almost 14 years ago)
The file you downloaded is not meant to be installed by users. If possible, please grab an installer for your platform.
If that is not possible (your platform might not have an appropriate installer released yet), then you can also unpack the tarball that you downloaded and place the "en" folder into $prefix/share/gimp/2.0/help where $prefix would /usr or /usr/local or wherever your GIMP installation resides.
Doug Huffman
2011-02-08 22:26:12 UTC (almost 14 years ago)
Thanks for the directions, they seem a bit linux-centric for me dozing over Windoze, and failing to mention that. If I can unpack a tar to an HTML, will my Windoze make such a difference?
snip
iQEcBAEBAgAGBQJNUcMEAAoJEIpOLnult3mg+zkH/2bN5YAyfIA+kNCb1aTcOu5m oypNwbMQAfqSXCtveCjwMLZPL6y/HOfg+q9QdRZs/yqDCPKILaXCNs1YzcuJPEGg pfLqM7V0ywQ9Hp10iX/WcrJz/pqQ2aBPqiIlUaYIzLZ6AuMxdufOk2QdAtej29mE JOzxhanv8AnvGgeLuZLd3AXfJMku8+GsfLRRsKo4rVwh1GYLI3sxi2BQhL5GRYZX SxmYhVe82H3DMBvdHzrgYYIs2ymXA67hhpyJ01Ysd54MynzdPHeDn6pwmBl7b/At pLwPnZ1ey/Dg7pcpAZQ3/IvOZ1DYaxQUbDhzwlPvSCYuUHkBP9Uzv4ynXTeBPGg= =BnMZ
rich
2011-02-09 08:59:54 UTC (almost 14 years ago)
snip
snipped a load of linux stuff
LOL
Always dangerous to assume, the .tar.bz2 format is very much a linux thing, gpg (mingw32) gpg should have been a clue.
For windows, first install gimp help 2.6 from sourceforge and check that it works.
http://gimp-win.sourceforge.net/stable.html
Then if you desperately want v2.61 unpack the archive. Use whatever you want but peazip works and there is a windows version.
then the (default) location is
C:\Program Files\GIMP-2.0\share\gimp\2.0\help\en
screenshot here.
http://imgur.com/bsAoI
rich
2011-02-09 09:00:45 UTC (almost 14 years ago)
snip
LOL
screenshot here.
