A simple for loop while using Colorize
7 of 7 messages available
A simple for loop while using Colorize Atrus 07 Jan 17:30
  A simple for loop while using Colorize Kevin Cozens 07 Jan 18:52
   A simple for loop while using Colorize Atrus 07 Jan 19:39
    A simple for loop while using Colorize Elwin Estle 07 Jan 19:44
    A simple for loop while using Colorize Kevin Cozens 07 Jan 20:04
     A simple for loop while using Colorize Atrus 07 Jan 20:13
  A simple for loop while using Colorize Chris Mohler 07 Jan 19:35
Atrus
2011-01-07 17:30:21 UTC (almost 15 years ago)
I'm looking to loop through and generate individual images by changing the "Hue" variable by 1 (ideally going from 1 - 360) and saving the resulting image.
So, my process is like this:
1. Set x to 1 2. Apply Colorize with Hue = x (all other values are at their default) 3. Save image as x.png
4. Undo to previous state.
5. Increment x by 1
6. Repeat steps 2-5 until x equals 361
What would be the best approach to accomplishing this?
Thanks, Tim
Kevin Cozens
2011-01-07 18:52:44 UTC (almost 15 years ago)
Atrus wrote:
1. Set x to 1
5. Increment x by 1
A small script written in Scheme or Python would be the best way to do the above. Doing it by hand will be very tedious. As I suspect you are about to say you wouldn't know how to write such a script, you would have to see if you can talk someone in to writing such a script for you.
BTW, hue values range from -180 through to 180 (inclusive) in GIMP.
Chris Mohler
2011-01-07 19:35:51 UTC (almost 15 years ago)
Try this plug-in I threw together: http://registry.gimp.org/node/24963
Screen capture of resulting files: http://registry.gimp.org/files/Screenshot-test-File_Browser.png
HTH, Chris
Atrus
2011-01-07 19:39:43 UTC (almost 15 years ago)
I was aware of scheme scripting, but not of python. I'll have to look into that. It shouldn't be too difficult.
However, I was going off of the "portable apps" version of GIMP as I was writing, which went from 0 to 360, not -180 to 180. Is that a version difference?
On Jan 7, 2011 1:53 PM, "Kevin Cozens" wrote:
Atrus wrote:
1. Set x to 1
2. Apply Colorize with Hue = x (all other values are at their default...
Elwin Estle
2011-01-07 19:44:15 UTC (almost 15 years ago)
Wonder if this couldn't be done with GAP?  If so, it would be trivial to do, just load the original, duplicate it enough times to get 360, then run through the frames with "apply filter varying".
--- On Fri, 1/7/11, Atrus wrote:
From: Atrus Subject: Re: [Gimp-user] A simple for loop while using Colorize To: "Kevin Cozens"
Cc: "gimp-user"
Date: Friday, January 7, 2011, 2:39 PM
I was aware of scheme scripting, but not of python. I'll have to look into that. It shouldn't be too difficult. However, I was going off of the "portable apps" version of GIMP as I was writing, which went from 0 to 360, not -180 to 180. Is that a version difference? On Jan 7, 2011 1:53 PM, "Kevin Cozens" wrote:
Atrus wrote:
1. Set x to 1
Gimp-user mailing list
-----Inline Attachment Follows-----
Kevin Cozens
2011-01-07 20:04:30 UTC (almost 15 years ago)
If you are using a portable version of GIMP, the files needed to support Python scripts are probably not available to you.
The -180 to 180 for hue is the range of the sliders in the GUI and is listed as the range in the Procedure Browser text in GIMP 2.6.7 (and later). The current version of GIMP as a portable app is 2.6.11 so it will have that same range.
Atrus
2011-01-07 20:13:26 UTC (almost 15 years ago)
The portable version was only temporary, as I was on a different computer. I have it installed at home. I'll try scripting with Google and python.
I have never herad of GAP, and thus enver used it. It does look impressive though, and I'll have to play with it at a further date. Tim Butram
http://www.worldsproject.org
On Fri, Jan 7, 2011 at 3:04 PM, Kevin Cozens wrote:
into
