Erasing with every Drawing tool
Erasing with every Drawing tool hannes61 24 Nov 11:13
  Erasing with every Drawing tool Tőkés Ábel 24 Nov 12:00
   Erasing with every Drawing tool hannes61 24 Nov 14:01
    Erasing with every Drawing tool Ofnuts 24 Nov 14:36
     Erasing with every Drawing tool hannes61 24 Nov 15:35
2010-11-24 11:13:56 UTC (over 14 years ago)
Wouldn't it be great if every tool could be used as an eraser?
Using the Airbrush in one color and removing something with it by choosing transparency.
This has the effect that the eraser has the same properties as the chosen tool.
For example the softness of airbrush. The effect of smudging,...
I would like to have something like that. :-)
Tőkés Ábel
2010-11-24 12:00:22 UTC (over 14 years ago)
Actually, this is possible. Change Mode to Color erase. If you have an alpha channel on the layer, it will erase to transparency.
Best regards, Abel
2010-11-24 14:01:45 UTC (over 14 years ago)
Best regards,
Abel
This is not the same.
This removes the color i had selected. If you use black and set the mode to color erase. Black is removed but all white parts stay. This is very cool, but does not work as the eraser, which does not differ on which color i selected.
It could gibe a mode erase. That's what i miss. :-) (SOMETIMES)
2010-11-24 14:36:14 UTC (over 14 years ago)
Best regards,
Abel
Wouldn't that be merely applying the tool to the layer mask?
2010-11-24 15:35:19 UTC (over 14 years ago)
Best regards,
Abel
It could give a mode erase. That's what i miss. :-) (SOMETIMES)
Sorry, i don't understand your question. :( Hm....
It would behave as a transparent area in the image or in the mask, depending where the drawing tool has been used.
And yes, sometimes it would replace the use of a mask.
But maybe your are right, this is not needed, cause it could be done by using a mask.
Black is delete or painting and white the opposite. :)
