Re : Re : Gimp and prepress functions
| Gimp and prepress functions | John Culleton | 23 Mar 19:36 |
| Gimp and prepress functions | Carol Spears | 23 Mar 20:26 |
| Re : Re: Gimp and prepress functions | Jean-Luc Coulon (f5ibh) | 23 Mar 22:29 |
| Gimp and prepress functions | Kelly Martin | 24 Mar 00:48 |
| Gimp and prepress functions | Sven Neumann | 24 Mar 01:59 |
| Re : Gimp and prepress functions | Jean-Luc Coulon (f5ibh) | 24 Mar 07:59 |
| Re : [Gimp- user] Gimp and prepress functi ons | Sven Neumann | 24 Mar 14:28 |
| Re : Re : Gimp and prepress functions | Jean-Luc Coulon (f5ibh) | 24 Mar 15:26 |
| Gimp and prepress functions | Kevin Myers | 24 Mar 02:50 |
| kmartin@pyrzqxgl.org | 07 Oct 20:16 | |
| Gimp and prepress functions | David Burren | 24 Mar 01:57 |
| Gimp and prepress functions | Kelly Martin | 24 Mar 02:10 |
| Gimp and prepress functions | David Burren | 24 Mar 03:34 |
| Gimp and prepress functions | Kelly Martin | 24 Mar 03:59 |
I recognize that Gimp is web-centric, and that enhanced prepress capabilities are somewhere in the future. However some of us do use Gimp for images ending up on the printed page. And critics of Gimp and Open Source software in general jump on prepress issues as a point of criticism.
In addition to CMYK the issue of ICC color profiles has been raised. Photoshop offers several profiles for e.g., coated paper, uncoated paper and so on. It is clumsy to develop in Gimp, and then transfer to Photoshop just for profiling. What are the prospects of doing something in this area? Is any of it on the agenda?
i am not certain what all color profiling needs. i have been following lcms mail list and still do not understand it.
i have been able to use gimp and templates to make web pages and i have planned to make LaTeX pages, however my time seems to be almost up.
carol.gimp.org is down right now -- for whatever reason, but i put a screenshot of a color dialog that has appeared in the new gimp. i am not certain if it meets your needs, but i would be curious to know how it fails to.
http://www.gimp.org/~carol/files/colorselector.png
the way to get this dialog in your gimp would be via the dialogs menu; it is called "Colors". as you can see from my screenshot, it is dockable.
truthfully, if you can print an html template you can easily print a LaTeX document. if you would be interested in seeing my scripts (python) send me a note and i will provide them for you.
Colormanagement is something needed if you want to process digital photography. You need along the whole process to know in which colour space you are working and to work with calibrated devices. Without a proper colormanagement, your photos on the screen will never have the same colours you see when you get them, and the prints you will get (with your inkjet printer, a minilab or any process) will never have the same colours you have seen (and adjusted) with the picture processing tool.
You can read some basics about colormanagement in the following paper:
http://www.adobe.com/support/techdocs/c9fe.htm
Regards
- Jean-Luc
lcms mail list and still do not understand it.i have been able to use gimp and templates to make web pages and i have
planned to make LaTeX pages, however my time seems to be almost up.carol.gimp.org is down right now -- for whatever reason, but i put a screenshot of a color dialog that has appeared in the new gimp. i am not certain if it meets your needs, but i would be curious to know how it fails to.
Someone would have to develop the profiles. The way Photoshop does it is by buying printers and doing test prints and gathering colorimetric data. The GIMP developers are short on people who have access to colorimetry labs, not to mention lots of printers.
A lot of the processes that go into prepress are tied up in patent and trade secret law. Getting those processes into the GIMP will be no easy task.
Kelly
This is a furphy. Generating the profiles is quite different from using them. There are existing libraries (e.g. lcms) to convert between colour spaces (defined by profiles) and there's even a Gimp plug-in to do this. There is even software for generating profiles for printers/scanners/etc (not part of the Gimp, but it doesn't have to be).
For accurate colour work you typically need to profile your own devices, as each has a slightly different colour response (e.g. for a printer it depends on the driver settings, the ink, and the paper choices). Monitors in particular constantly change their behaviour and need to be reprofiled regularly. Good print labs profile their devices and provide the profiles to their clients. It's not up to the Gimp to generate profiles, it's up to the Gimp to use them.
Unfortunately Gimp has a way to go before it has a concept of your monitor colour space (and dynamically converting displayed images into that colour space) and a colour space for each image. This is something that Photoshop (and most of the other Adobe software) does very well. The Gimp has a plain model where there is only one colour space: your monitor's. Everything is dealt with as just RGB (disregarding the HSV/etc composition/decomposition feature) and sent to your monitor as-is. I think a more-sophisticated model is required to support a colour-managed workflow (and things like 16-bit support, CMYK, L*a*b, etc are just part of that).
Other projects like CinePaint (nee FilmGimp) are making progress
on this. Hopefully the Gimp will catch up. But I don't think
"patent and trade secret law" has much to do with it.
__
David Burren
John Culleton writes:
GIMP 2.0 comes with a color proof display filter that uses ICC color profiles to simulate a proof on your monitor. Support for such filters is new in 2.0 and for the future it is planned to integrate display filter modules better into the workflow.
My gf used to work for a large prepress company. They spent a lot of money generating and validating matching profiles, and they're not going to just give them to anyone. If you want them, you pay for them.
That's where the trade secret law comes in.
Kelly
In my recent experience, ICC (or ICM or both?) profiles are included with a lot of newer hardware, and/or they can be downloaded from the manufacturer's web sites. That seems to be increasingly prevelant, at least as far as devices with Windows support are concerned. I don't know much about these profiles, but it appears that these can be used across multiple applications. Under Windows, files with .icc and .icm extensions are normally installed under the %windir%\system32\spool\drivers\color directory. Right now, there are about 50 of those files installed on one of my machines, including a significant number that appear to be for hardware that I don't even own.
My first conclusion is that a signifcant number of color profiles appear to now be either included with hardware (such as monitors, scanners, and printers), included with various applications (e.g Corel Draw), and/or included with the Windows OS. My second conclusion is that it seems reasonable that the Gimp *might* be able to use these, since they don't appear to be application-specific. However, I don't know anything about the format or content of those files, nor how to go about selecting and using the profile that is appropriate for a particular device. So, I don't know whether these same files might be usable under Linux for example, nor how difficult it might be to enable use of them from the gimp. Mainly I just wanted to offer these observations in case they might be applicable to the availability issue.
s/KAM
----- Original Message ---
This is silly. The profiles would be for their specific machines, and would be useless with anyone else's (even with the same make hardware, as the knobs and dials would probably not be in "standard" positions). The choice of ink and paper stock are also factors. I'm not saying the prepress company wouldn't do it, just that I think it would be a completely silly reason for not supplying the target profile.
Even if they did not want to provide the final profiles, if they want any chance of supporting a digital colour-managed workflow they would have to accept files tagged with other profiles (e.g. AdobeRGB, sRGB, ProPhotoRGB, various CMYK colour spaces, etc) and do the conversion in-house.
One of the labs I deal with has its own intermediate colour space that it gets us to convert to, so internally they can manage the choice of printer/paper/etc for each job and update the target profiles whenever they calibrate the machines (without having to send them out to all the clients).
Those intermediate colour spaces should be available to the Gimp (although there _are_ copyright considerations with the profiles). The format of these ICC profiles is defined in a standard, and the lcms library already knows how to deal with them.
Cheers
__
David
Indeed. Their clients (Fortune 500 companies, every last one of them) pay dearly for them to develop exact color matching profiles that match the specific printing presses, stock, and inks they use.
Kelly
I've used the colour proof display filter with profiles I built with an eye one spectrophotometer from GretagMacbeth. This allows be at least to have the right colours on the screen while the photos I get from my digital slr camera. This is one step in the right direction. But only the display is affected: the output is left unmodified.
There is also the need (with digital photography in mind and this is a growing usage of tools like The Gimp) to work in a given colour space (i.e. sRGB or Adobe RBG 1998) and the used colour space should be included in the final picture ready to prints: most of the labs need this information so that you get the picture unmodified. Without the colour space information, most of the time, the colours are shifted and your work is ruined.
"Jean-Luc Coulon (f5ibh)" writes:
There's also things going into that direction. There are two enhanced TIFF plug-ins that work with color profiles and we will look to get this functionality included in the GIMP distribution.
For the more long-term future, support for other colorspaces than RGB and for more color-depth than 8bit/channel is planned and is actually already being worked on.
color
filters
an
my
That is good news.
- As my camera support 12bits depth there will be more dynamic range to
do the post-processing (together with dcraw from Dave Coffin).
- When I ask for prints to colormailer pro service they ask to have the
colour space embedded in the file otherwise the pictures are
"interpreted" by the lab and there is some colour shift.
Regards
- Jean-Luc
