Set exact print size
Set exact print size uluru75 12 May 18:46
  Set exact print size Branko Vukelic 12 May 19:14
  Set exact print size Burnie West 12 May 22:18
2010-05-12 18:46:35 UTC (about 15 years ago)
I have a problem with setting print size of images. When i set it to 148mm and 105mm, it's being set, then i save and close the image.
However, when i re-open the jpg, it often show the sizes like 148.22mm or 105.05. Basically i don't want anything after the dot, i want exact size. Does anyone has any idea how to fix it?
Branko Vukelic
2010-05-12 19:14:15 UTC (about 15 years ago)
It's probably a series of rounding errors when converting mm to inches and then inches to pixels. The image should have:
148mm / 25.4mmpi = 5.82677165" 5.82677165" * 300ppi = 1748.0314950000002 px
105mm / 25.4mmpi = 4.133858267716536" 4.133858267716536" * 300ppi = 1240.1574803149608 px
as you can see, not clean round number. You should have something like 1748px x 1240px which translates to roughly 148x104.99mm.
-- uluru75 (via www.gimpusers.com)
Burnie West
2010-05-12 22:18:00 UTC (about 15 years ago)
Images are always saved in integer numbers of pixels.
To get exactly 148mm by 105 mm, a mm should be an exact number of pixels.
The number of pixels you mention is not exactly commensurate with a 148 x 105 mm image,
so the image (if it's really 148.22 x 105.05) will have to be scaled to be a little bit shorter.
So in the Image->Scale Image tool, select image size in mm, but don't scale it yet.
Then set the X-Y resolution to exactly number of pixels you want in a mm (10, say). This makes the specified print size come out exactly in pixels.
Then, click on the chain link on the Image Size x-y pair, so the image can be scaled to exactly the dimensions you want. Notice that 72 pixels per inch is 2.8346567 pixels/mm.
Now, enter 148 in the Width textbox and 105 in the Height textbox (the pixels/mm entry should not change). NOW, scale the image. On this user list, people have mentioned a few times that the best scaling quality seems to be Sinc (Lanczos3) interpolation, but YMMV.
Actually, when I did this with a 3872x2592 pixel image, then saved and reopened the image, it reopened with the image size default set to inches, and then when I converted that image size to mm, it said 148.01 x 105.01. Then, when I clicked in the pixels/mm box, then the height box, the .01's went away by themselves. This suggests it was a rounding error, rather than a size problem.
