Tablet Problems
Tablet Problems Zophu 03 Apr 02:23
  Tablet Problems Branko Vukelic 03 Apr 03:40
   Tablet Problems Zophu 03 Apr 22:03
2010-04-03 02:23:14 UTC (about 15 years ago)
Tablet Problems
I use my tablet only on a portion of the screen. This would be fine with GIMP as I center the editable image in the area my tablet can use. BUT whenever I change tools and tool options with my mouse, (which can reach outside of the center area and edit various options,) I find that using the tablet again reverts to whatever the options were before I changed them. Is there anyway to prevent this or am I done with GIMP?
Branko Vukelic
2010-04-03 03:40:01 UTC (about 15 years ago)
Tablet Problems
For each input device (mouse, pen, eraser), GIMP assigns tools separately. So I suggest you:
a) come up with a bunch of shortcuts for your tools b) position the toolbox right over the are you use with your tablet, and press to hide the toolbox
2010-04-03 22:03:36 UTC (about 15 years ago)
Tablet Problems
GIMP
I
the
anyway to
Oh, well. Thanks for the advice. I'll try it before giving up and moving on to something else :)
