GIMP won't load LARGE TIF file
GIMP won't load LARGE TIF file lkraemer 07 Mar 20:45
  GIMP won't load LARGE TIF file Tobias Jakobs 07 Mar 21:04
   GIMP won't load LARGE TIF file lkraemer 08 Mar 20:59
    GIMP won't load LARGE TIF file Sven Neumann 08 Mar 21:21
  GIMP won't load LARGE TIF file GSR - FR 07 Mar 21:38
2010-03-07 20:45:09 UTC (about 15 years ago)
I had some plans scanned at Zephyr Printing. They scanned the Large drawings at 600DPI, 1 Bit Black, and saved the files. The pixel sizes of the drawings are 21600 x 33184. The files also have the Fax Group 4 designation.
I can't load these drawings into Gimp 2.6, or view them with any Ubuntu Software. I have used Irfanview to view them, so at least I can rename each file according to what is located inside the file.
Has anyone had trouble using with such a large sized file?
Any help would be appreciated.
Thanks.
lk
Tobias Jakobs
2010-03-07 21:04:30 UTC (about 15 years ago)
Can you upload somewhere such a file? Which operating system do you use?
Which exact Gimp version do you use? Are there any warnings or errors?
Regards, Tobias
GSR - FR
2010-03-07 21:38:25 UTC (about 15 years ago)
forums@gimpusers.com (2010-03-07 at 2045.09 +0100):
IIRC GIMP uses 5 bytes minimum per canvas pixel: 1 selection + 4 RGBA projection. So 21600 * 33184 * 5 = 3583872000, over 3GB just to show the image.
This is without counting the real pixel data, I do not rememember which happens with paletized or grey images, they could use 1 byte per pixel of the single layer or require expansion to 3-4, so the real number could be >5GB (if someone uses this formula for other images, in multilayer case, add the pixels each one use, obviously).
Which means you need a 64 bit computer and OS, a lot of memory and a really fast memory bus... and based in comments of a person than regularly works with 10000 pixel images, a lot of patience too (6 "patiences", as your case is 6 times bigger). Maybe GIMP is not the tool you need.
GSR
2010-03-08 20:59:39 UTC (about 15 years ago)
Tobias,
Here are the answers to your questions.
An incomplete scanned file, which is a bit larger has been uploaded here:
http://www.filefactory.com/file/b08c72g/n/Temp00395.Tif
The file size is 3.72 Meg and Pixel size is 21600 x 36000 at 1BPP.
Ubuntu 9.10 32 Bit with all the latest updates & Gnome Desktop.
GIMP Ver 2.6.7 included with Ubuntu Install ISO.
No Warnings or errors, but the screen does go dim and GIMP just hangs, eventually wanting a FORCED Quit.
I have installed Irfanview in WINE 1.0.1. I have just tried opening this file in Irfanview 4.23, then saving it to Temp00395a.Tif, and then I can load this new saved Tif in Gimp Ver 2.6.7......but it takes forever.
Computer is a Compaq Laptop CQ50-139NR with Core II Duo with 3 Gig RAM and 500 Gig Drive, with Ubuntu on a 127 Gig Partition.
Thanks.
lk
2010-03-08 21:21:07 UTC (about 15 years ago)
You've read the answer in this thread that explains why this is happening, didn't you?
