What is the best way to fade an edge
What is the best way to fade an edge ScottDB 20 Feb 19:55
  What is the best way to fade an edge Stefan Maerz 20 Feb 20:02
  What is the best way to fade an edge Akkana Peck 20 Feb 20:07
  What is the best way to fade an edge Sven Neumann 20 Feb 20:34
2010-02-20 19:55:29 UTC (about 15 years ago)
Hi all I was wondering what would be the best way to fade the edge of a pic so that it fades into nothing.
Stefan Maerz
2010-02-20 20:02:35 UTC (about 15 years ago)
Quite Simple.
With your selection, 1.Right Click/select/shrink select how many pixels. 2. RIght Click/select/invert
3. Right Click/select/feather.
I think this is what you are looking for.
Akkana Peck
2010-02-20 20:07:01 UTC (about 15 years ago)
Scott writes:
Here are several ways to do it (not a great tutorial, sorry -- I made it a long time ago): http://www.shallowsky.com/linux/quickmask/
...Akkana
2010-02-20 20:34:41 UTC (about 15 years ago)
Have you had a look at
http://www.gimp.org/tutorials/Quickmask/ ?
