Moving images from point a to b animated
21 of 22 messages available
Moving images from point a to b animated ScottDB 20 Feb 00:20
  Moving images from point a to b animated Burnie West 20 Feb 03:04
   Moving images from point a to b animated ScottDB 20 Feb 08:05
    Moving images from point a to b animated Burnie West 20 Feb 09:48
     Moving images from point a to b animated David Gowers 20 Feb 10:05
      Moving images from point a to b animated Burnie West 20 Feb 18:49
       Moving images from point a to b animated Olivier Lecarme 20 Feb 19:04
        Moving images from point a to b animated ScottDB 20 Feb 19:51
         Moving images from point a to b animated saulgoode@flashingtwelve.brickfilms.com 21 Feb 10:37
          Moving images from point a to b animated ScottDB 22 Feb 05:11
        Moving images from point a to b animated Burnie West 20 Feb 20:41
         Moving images from point a to b animated Olivier Lecarme 21 Feb 09:07
          Moving images from point a to b animated ScottDB 22 Feb 23:56
           Moving images from point a to b animated Sven Neumann 23 Feb 08:45
            Moving images from point a to b animated ScottDB 23 Feb 09:42
             Moving images from point a to b animated Olivier Lecarme 23 Feb 17:19
             Moving images from point a to b animated saulgoode@flashingtwelve.brickfilms.com 23 Feb 19:40
              Moving images from point a to b animated ScottDB 23 Feb 23:41
               Moving images from point a to b animated Olivier Lecarme 24 Feb 07:32
                Moving images from point a to b animated ScottDB 24 Feb 18:25
mailman.1.1266955203.10819.... 07 Oct 20:20
  Moving images from point a to b animated Alchemie foto\\grafiche 24 Feb 19:52
2010-02-20 00:20:49 UTC (about 15 years ago)
I'm not even sure what it is called or how to go about a search for it. I would like to have a train go accross the bottom of the picture and stop at the far end.
I did my first animated last night with the searches and I would like this train to go accross the bottom.
This is not a link add just a pic.
http://newbiescentralexch.com/00image/s/exchbann2.gif
I know it needs to be cleaned up.
Burnie West
2010-02-20 03:04:55 UTC (about 15 years ago)
I don't see animation. Seems like the animation you've attempted should appear in the header1 image; but that's a jpg but not a gif.
2010-02-20 08:05:00 UTC (about 15 years ago)
Well it is my first atempt and I just did what the forum post that I was going off of in a search said to do. Looked for a good tutorial for it but couldn't find one.
Yes the train now that I think about it was a jpg. I just took one layer out of an exsisting animation and made my own and saved as a gif. Any links to a good tutorials for this?
Burnie West
2010-02-20 09:48:18 UTC (about 15 years ago)
I looked at a couple of tutorials for it, and they don't exactly seem to address
your questions very well. They tend to be overly simplified, or assume too much
background knowledge.
WARNING: very wordy post (but I don't know how to help otherwise).
Basically, you need to create a layer for each animation frame. Then you need to
organize the layers in the animation sequence. Then you need to schedule them.
If the animation from which you took that picture has the train moving the way
you want, maybe you can get the whole thing as an animated gif. But please pay
attention to the source copyright if there is one.....
In the case of the train in your jpg image, there are some complications. As the
train runs along the track, it will change size and perspective; it goes behind two
buildings and two trees, and all of that has to be accommodated.
So I would suggest the following process (and I am quite sure there are others
with more skill and experience than I).
1) Decide how fast you want the train to move, and how many frames you need. Five frames per second for four seconds is a total of twenty frames. It's pretty
jerky but may be OK. You can expand if you want, but each frame takes a few minutes of work once the basics are completed.
2) Extract the parts of the two buildings and the two trees behind which the train
will run, and put them together in a separate layer - let's call it the foreground.
I would use the lasso tool for that.
3) Make another layer with the train. Use a careful outline of the train, again with
the lasso tool.
Now come the hard parts. You need to prepare the background layer (remember, Walt Disney hired hundreds of animators to paint cells for his animated movies).
Then you need to create multiple copies of the train with the right size, orientation and perspective. Then you need to place them and combine them with the foreground and background layers. These are the steps I would take.
4) Remove the train image. This involves generating an image of the tracks and
the lawn and stuff where the train occludes them.
5) When you have a satisfactory background image, then make 20 copies of your
carefully excised train. Each copy is a separate layer.
6) Place the twenty trains where you want them on the tracks.
7) Using the perspective and rotate tools, adjust the perspective, size, and orientation
of the train so it looks right on the segment of the track it occupies. Since the image
is two-dimensional and the train is really a three-dimensional object, you may have to
play around a bit to get it to look tolerable.
8) At this point, you might like to hide the foreground and background layers, and
save the result as an animated gif to get the animation to flow the way you want.
This will produce a twenty-frame image of a train running in empty space.
9) Once the train running across the empty space looks good, you are now ready
to create the full image for each of the frames. You'll probably want to save this
gif animation as a separate file for later tweaking. And save the foreground and
background images as well.
10) Now create the frames. Make twenty copies of the foreground and twenty copies
of the background in the xcf image that contains the twenty scaled and rotated
trains. Place a foreground layer above each train image layer, and a background
layer below it. It's probably a good idea to save this image as a temporary checkpoint.
Merge the foreground layer down onto the train image layer, and then merge this layer down into the associated background layer.
11) Under the Filters menu, select Animation->Playback. If the frame sequence is
correct, the train should run along the track behind the two buildings and the two
trees, and then (if you kept the "Looping" box checked) do it all over again.
I guarantee you, if you are anything like me, you won't like your first attempt very
much. But the second will be better, believe me.
David Gowers
2010-02-20 10:05:30 UTC (about 15 years ago)
Or you use GIMP-GAP, which is designed for this kind of thing and has the 'Move path' tool to do pretty much everything except extracting the train :)
Burnie West
2010-02-20 18:49:57 UTC (about 15 years ago)
AFAICS, GAP move path tool doesn't handle the train scaling, perspective shifts, rotations, foreground occlusions, and the 3-D/2-D aspects. All that would have to be managed by hand on a frame-by-frame basis, would it not?
These leaves the frame compositing and the tracking, which are really the easiest to tackle (at least at my level of expertise).
Olivier Lecarme
2010-02-20 19:04:39 UTC (about 15 years ago)
No, the Move Path tool offers exactly what is needed: you define the path along which the train moves, and you define the transformations on it: zooming in or out, rotating, perspective, fading, and so on.
There are several short tutorials about this tool. In the GIMP book I'm preparing, there will be a full chapter about it.
2010-02-20 19:51:52 UTC (about 15 years ago)
hey thanks all for the information. I just noticed that the link in the original post is bad. It is supposed to be images/ - not image/s/. I think that will make things a lot easier.
Burnie West
2010-02-20 20:41:26 UTC (about 15 years ago)
That's terrific, Oliver. I searched through Akkana Peck's wonderful book Beginning Gimp and with that source I've done a very few animations for fun. But she didn't mention GAP - probably wasn't available at the time she was writing.
I'm looking forward to yours.
Olivier Lecarme
2010-02-21 09:07:50 UTC (about 15 years ago)
That's terrific, Oliver. I searched through Akkana Peck's wonderful book Beginning Gimp and with that source I've done a very few animations for fun. But she didn't mention GAP - probably wasn't available at the time she was writing. I'm looking forward to yours.
Unfortunately, you'll have to be patient. Since the book will be a large one, and we try to synchronize it with version 2.8 of GIMP, you'll have to wait for one year (hopefully not more).
2010-02-21 10:37:25 UTC (about 15 years ago)
Quoting Scott :
So do you mean you just want a train moving across the bottom of the banner? -- for example, something similar to:
http://www.freeimagehosting.net/uploads/eb521b8ef6.gif
2010-02-22 05:11:03 UTC (about 15 years ago)
Quoting Scott :
think
Thats what I wanted but without the jerkey start. Might have been my browser as well. Also want it to stop at the end. It actually isn't going on this baner. I am making a splash page for it to go across the bottom and stop at a train station where there will be a link to go to site.
2010-02-22 23:56:51 UTC (about 15 years ago)
Hi all and thanks for oall the comments. I finally figured out how to install the gap into my gimp. Now that I look at the settings I am more confused as ever. Can someone help me get started on this. Just need the image to move in a strait line. Here is what I am trying to get to move across the page. I imagine it is very basic for this type of work.
http://newbiescentral.com/0sqzpgcamp/images/test.html
2010-02-23 08:45:39 UTC (about 15 years ago)
Have you had a look at the introductory GAP tutorial at the gimp.org web-site?
http://www.gimp.org/tutorials/Using_GAP/
2010-02-23 09:42:49 UTC (about 15 years ago)
Yes I have read that one as well as a dozen others. I found a realy good one for beginers.
http://www.gimptalk.com/forum/gap-beginner-tutorial-set-t9266.html
The problem I am having now is that when I go to video/move path and then try and edit the source image layer it is empty. How do I get the image in it.
Olivier Lecarme
2010-02-23 17:19:11 UTC (about 15 years ago)
If you give me a personal address (forums@gimpusers.com is not), I could send you more detailed explanations.
2010-02-23 19:40:01 UTC (about 15 years ago)
Quoting Scott :
For your source image to be available to Move Path, it must be of the same base type (RGB, Grayscale, or Indexed) as the target image. For example, if your source image came from a GIF file then it is likely still in Indexed mode, and must be converted to RGB mode before it can be used by Move Path.
2010-02-23 23:41:02 UTC (about 15 years ago)
Hey thanks for the information. That was the problem was the image was in index mode. Changed it over to RGB and got things to work. I am sitll having problems but making progress.
Hey Olivier I could definatly use some help here. If you would like to contact me at scottpersonal61@gmail.com I would appreciate it.
Here is what I have got so far and you can see the problem. I also would like the train to go a lot slower and also stop at the end. The train is only 2 cars long. Tried it like a dozen times and did get it to slow up once but still get the other effects.
http://newbiescentralexch.com/00images/splash/animtrain.gif
Thanks, Scott
Olivier Lecarme
2010-02-24 07:32:14 UTC (about 15 years ago)
I'll do it today.
To slow up the movement, you need to set the delay in each frame to more than the default. To make each new frame hide the preceding one, you need to set it in (replace) mode. Thus the name of a given frame would be
frame#xx (replace) (200ms)
for example. Then the train would simply move on the Web page. To stop it at the end, you need to replace the image itself by another one, or at least put a very very long delay in the last frame, say 100000ms.
However, when you will use GAP's Move Path tool, it will be much easier, and above all you will be able to have a stable landscape behind the train, without being obliged to copy and merge the corresponding layer with all frames of the animation.
2010-02-24 18:25:14 UTC (about 15 years ago)
having
I'll do it today.
like
I am using the Gap move path tool to do this. I couldn't find replace mode in the gap move path tool so I tried frame once mode and it seemed to work. I got it to slow down by changing the (ms) in the frames but now it is kind of jerky. I know I must be missing something
Example here: http://newbiescentralexch.com/00images/temp/train2.gif
2010-02-24 19:52:09 UTC (about 15 years ago)
The problem I am having now is that when I go to video/move path and then >try and edit the source image layer it is empty. How do I get the image in it.
Gap is more geared towards "Frames" then "Layers" animation
Meaning that your input image may be a layer but a layer of a frame ("Frames" are images, but name with a progressive number..as 00001-image.xcf a frame may have only 1 or more layer )
Its a quite important point if you don't want work with frames but only with single image with many layers may be better found some alternative to GAP
As example this script http://www.gimptalk.com/forum/-script-fu-move-layers-similar-to-gap%CA%B9s-move-path--t46740.html
and the other of same author you will found in the first page of that board
About the advantage of Frames anymationVS layer animation is simple: a complex animation may require a lot of layer to be smooth And a image with some hundreds of layer may easily become too big, as file size , may become impossible save or open it without crashes
Working with frames if your computer has sufficient memory to process the first, then will be able to process also the others (since once created they are automatically saved and loaded only when needed ..they don't need to be all loaded simultaneously But in case of layers of same image is the contrary, you may not load only a couple of layer but only all the image
