Create a clickable hotspot?
7 of 7 messages available
Create a clickable hotspot? BGP 19 Jan 16:02
  Create a clickable hotspot? yahvuu 19 Jan 16:24
   Create a clickable hotspot? BGP 19 Jan 21:32
    Create a clickable hotspot? Owen 19 Jan 22:43
     Create a clickable hotspot? Greg Chapman 20 Jan 10:17
    Create a clickable hotspot? Ludmilla 12 Jul 13:04
     Create a clickable hotspot? Akkana Peck 13 Jul 01:48
BGP
2010-01-19 16:02:50 UTC (over 15 years ago)
How do I create a clickable hotspot in GIMP?
I have a BMP image that I want to put on the web. When you click on certain portions of the picture it'll take you to different web pages.
yahvuu
2010-01-19 16:24:28 UTC (over 15 years ago)
hi BGP,
Filters->Web->Image Map will do the job.
Documentation is here: http://docs.gimp.org/2.6/en/plug-in-imagemap.html
have fun, peter
BGP
2010-01-19 21:32:36 UTC (over 15 years ago)
Thank you. I can create the hotspots on the picture I'm using but how do I add it into my web page? I'm using Kompozer which doesn't want to import the thing.....it's a MAP file or some sort of thing.
Any idea what to do?
On 10-01-19 10:24 AM, yahvuu wrote:
hi BGP,
have fun, peter
Owen
2010-01-19 22:43:13 UTC (over 15 years ago)
hi BGP,
Not sure what Kompozer is, but I suggest you will probably need to do some hand coding
Open up you .map file in a text editor. have a read and see what it does
remove the comments if you wish
Now open up your web page in the text editor copy and paste your .map file into the web page file where you want it
Greg Chapman
2010-01-20 10:17:54 UTC (over 15 years ago)
Hi Owen,
KompoZer (http://www.kompozer.net) is an excellent open source WYSIWYG web page editor that runs under Windows, Linux and Mac.
As this really seems to be a KompoZer issue the OP would be better visiting:
http://wysifauthoring.informe.com/forum/
where they'll be plenty of help.
Greg Chapman http://www.gregtutor.plus.com
Helping new users of KompoZer and The GIMP
2010-07-12 13:04:26 UTC (almost 15 years ago)
Hi, BGP
I wonder if you have found out how it works - to insert a hotspot in kompozer - if it works at all.
I'm not sure to be able to write any single code - I'm just a user of Gimp and Kompozer and would be thankfull for any copy-paste solution.
Akkana Peck
2010-07-13 01:48:48 UTC (almost 15 years ago)
Ludmilla writes:
I'm guessing you're talking about making an image map. You can create HTML imagemaps in GIMP using Filters->Web->Image Map... -- see the documentation at http://docs.gimp.org/2.6/en/plug-in-imagemap.html.
But if you're having trouble importing the map into Kompozer, you might have better luck asking on a Kompozer list. They'll probably need specifics of what goes wrong when you try to import it: the message you quoted didn't mention that.
...Akkana
