How to install? -- was How to despeckle?
4 of 5 messages available
How to despeckle? Jonathan Ryshpan 02 Dec 11:56
  How to despeckle? David Hodson 02 Dec 12:19
4B17BF9E.8060506@gmail.com 07 Oct 20:20
  How to install? -- was How to despeckle? Jonathan Ryshpan 04 Dec 21:35
   How to install? -- was How to despeckle? Michael Schumacher 05 Dec 03:45
Jonathan Ryshpan
2009-12-02 11:56:50 UTC (over 15 years ago)
How to despeckle?
Attached is a small fragment of a tiff file; it has a large number of speckles, which I'd like to remove. The natural tool would seem to be Despeckle, but it doesn't seem to do the job. In fact, as far as I can see, it doesn't do anything.
What's the right tool to use? Or maybe I'm not using Despeckle right.
Any help much appreciated - jon
David Hodson
2009-12-02 12:19:05 UTC (over 15 years ago)
How to despeckle?
Set image mode to RGB, Filter->despeckle->set Black level to -1 and White level to 256. Set image mode back to indexed if you like. Works fine.
-- David
Jonathan Ryshpan
2009-12-04 21:35:41 UTC (over 15 years ago)
On Thu, 2009-12-03 at 14:39 +0100, Claus Cyrny wrote:
I would recommend you to donwload & install the 'GREYCstoration' plug-in
from the Gimp plug-in page. It does a much better job than the Gimp's own 'Despeckle'
filter. After installing it, you can find the plug-in under
'Filters > Enhance > GREYCstoration...'
For a start, I would set 'Strength' to maybe 25 or so & leave the other options as they are.
Thanks very much for the pointer. I went to the link you mentioned, which advised me:
This plug-in has been superseded by the G'MIC plug-in for GIMP
I have downloaded G'MIC and unzipped it, but it's not clear how to install it. I would guess that it should simply be copied to /usr/lib64/gimp/2.0/plug-ins, but this procedure doesn't seem to be documented anywhere. Or maybe it's better to copy it to $HOME/.gimp-2.6/plug-ins . Or maybe something else.
The most promising looking tool, gimp-plugin-mgr, produces an error:
$ gimp-plugin-mgr --install gmic_gimp gimp-plugin-mgr: can't read /etc/gimp/plugins.d/gmic_gimp.conf
It's a good idea to check before charging ahead.
BTW: How carefully are the plugins in the Gimp Plugin Registry checked for trojans, etc?
Thanks - jon
2009-12-05 03:45:41 UTC (over 15 years ago)
*BTW:* How carefully are the plugins in the Gimp Plugin Registry checked for trojans, etc?
Not at all.
