Brush edit problem
Brush edit problem Fluffmeister 20 Nov 18:30
  Brush edit problem devvv 20 Nov 20:34
  Brush edit problem David Gowers 20 Nov 22:46
   Brush edit problem Fluffmeister 21 Nov 00:12
    Brush edit problem Patrick Horgan 21 Nov 00:29
2009-11-20 18:30:53 UTC (over 15 years ago)
Brush edit problem
I want to create a straight line that's two pixels wide. There's a brush that's 1px, and another that's 3px, so I created a new brush, made it a square one and selected a radius of 1.0px. If I do this, the brush appears to be 3px in width.
So I tried various values. 0.7px radius still gives me a brush that is 3px wide. However, 0.6px radius gives me one that is 1px wide. I don't seem to be able to find any setting that makes it 2px wide, and neither can I understand the relationship between "radius" and the actual size of the brush. The same thing happens with higher values - anything from 0.7 up to 1.6 gives me a brush that's 3px wide, then at 1.7 it jumps to 5 pixels.
Is it impossible to have a brush that is an even number of pixels wide, and if so, why?
2009-11-20 20:34:46 UTC (over 15 years ago)
Brush edit problem
square
3px
in width.
be
understand
same
Better use a path and use the "stroke path" option in the paths dialog! You can enter a specific value there, and you can use different line types too (from solid to dashed and/or dotted). pretty cool...
Hope that helps ;)
David Gowers
2009-11-20 22:46:18 UTC (over 15 years ago)
Brush edit problem
No, but it may be impossible to have an even sized 'virtual' brush, which is the type you're editing.
You may need to create a 2x2 grayscale image filled with black* and save it with a 'gbr' extension to your brushes directory.(then refresh the brushes dialog)
* or is it white? one of those two.
2009-11-21 00:12:10 UTC (over 15 years ago)
Brush edit problem
Ah OK - many thanks for both your suggestions :)
Patrick Horgan
2009-11-21 00:29:50 UTC (over 15 years ago)
Brush edit problem
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
Why not use the 1x1 with scaling set to 2?
Patrick
