Filters/Distorts/Mosaic Tile spacing 0 ?
Filters/Distorts/Mosaic Tile spacing 0 ? Jos van Riswick 14 Nov 12:30
  Filters/Distorts/Mosaic Tile spacing 0 ? Owen 14 Nov 22:06
Jos van Riswick
2009-11-14 12:30:14 UTC (about 16 years ago)
Hello
is there some way to create a mosaic from a photo (ie convert to to triangular/hexagonal patches of color) with no black edge inbetween the tiles? In Filters/Distorts/Mosaic, the mallest tile spacing is 1, leaving a smale edge. Is there a way to set this to 0 ? If not I'd like to submit this as a feature request. Where can I do this?
josvanr
Owen
2009-11-14 22:06:29 UTC (about 16 years ago)
Hello
AFAIK, the mosaic plug-in is a compiled object, so you need to look at the source, plug-ins/common/mosaic.c and fiddle with that.
I just tried one change, setting the tile spacing to 0.0 but while that sort of narrowed the spacing, there is something else that needs to be changed
So if you are into programming, you can play with that, otherwise submit a request for an enhancement, *BUT* read para 2 of http://www.gimp.org/bugs/ first
