Anchoring a layer in script-fu
Anchoring a layer in script-fu Dave 77459 21 Oct 18:20
Dave 77459
2009-10-21 18:20:40 UTC (about 16 years ago)
I am automating a "LAB Enhancement" process. It is found here:
http://www.dslreports.com/forum/remark,15173919
In short, you decompose to LAB. You monkey with the A and B channels, then use curves on L. Finally, you recompose.
One issue is that you have to copy the resulting A1 and B1 channels, and then anchor them back into the original A and B channels so that you can recompose. Merging down into A or B apparently creates new layers and you lose the ability to recompose.
The attached script for version 2.6.2 gets to the last step that I am going to (I'm stopping before applying curves to the L channel because I'll do that manually depending on the image). I create the altered A1 and B1 channels. I paste B1 and anchor it into B.
However, when I paste A1, it is anchoring into B, instead of A. A is the top layer, but I can't get the script to anchor into it. When I anchor manually, it also anchors into B. I'm frustrated and mystified in equal measure.
Another side effect is that running this script wipes out the filters, and I have to refresh them. :-(
Can any Script-fu wizards out there tell me what I am doing wrong?
Dave
---- script follows and is attached ----
; LAB Enhance ; David Hathaway
; Based on:
; http://www.dslreports.com/forum/remark,15173919 ;
; v 0.5 - 21 OCT 2009 (first working version)
(define (LAB-Enhance img drawable)
(gimp-image-undo-group-start img)
; set some system variables (let*
(width (car (gimp-image-width img))) (height (car (gimp-image-height img))) (blend-layer)
(b-copy1-layer)
(b-copy2-layer)
(a-copy1-layer)
(a-copy2-layer)
(layers (gimp-image-get-layers img)) (B1)
(B2)
(B3)
(editcopy)
(A1)
(A2)
(A3)
; copy A channel and add as second layer (set! A1 (car (gimp-layer-new-from-drawable ( aref (cadr layers) 1) img)))
(gimp-drawable-set-name A1 "A 1")
(gimp-image-add-layer img A1 1)
(gimp-image-undo-group-end img) (gimp-image-undo-group-start img)
; copy B channel and set as 4th layer (set! B1 (car (gimp-layer-new-from-drawable ( aref (cadr layers) 2) img)))
(gimp-drawable-set-name B1 "B 1") (gimp-image-add-layer img B1 3)
; copy the B channel copy and make overlay, inserting as 4th layer (set! B2 (car (gimp-layer-new-from-drawable ( aref (cadr layers) 2) img)))
(gimp-drawable-set-name B2 "B 2") (gimp-layer-set-mode B2 OVERLAY-MODE) (gimp-image-add-layer img B2 3)
; merge new B channels (set! B3 (gimp-image-merge-down img B2 EXPAND-AS-NECESSARY))
; copy the A channel copy and make overlay, inserting as 2nd layer (set! A2 (car (gimp-layer-new-from-drawable ( aref (cadr layers) 1) img)))
(gimp-drawable-set-name A2 "A 2") (gimp-layer-set-mode A2 OVERLAY-MODE) (gimp-image-add-layer img A2 1)
; merge new B channels (set! A3 (gimp-image-merge-down img A2 EXPAND-AS-NECESSARY))
; move B to top (gimp-image-raise-layer-to-top img (aref (cadr layers) 2))
; cut B1, paste into layer, and anchor (gimp-image-set-active-layer img (aref (cadr (gimp-image-get-layers img)) 4))
(gimp-selection-all img)
(gimp-edit-cut (aref (cadr (gimp-image-get-layers img)) 4)) (gimp-image-set-active-layer img (aref (cadr (gimp-image-get-layers img)) 0))
(gimp-floating-sel-anchor (car (gimp-edit-paste drawable TRUE)))
; move A to top (gimp-image-raise-layer-to-top img (aref (cadr layers) 1)) (gimp-image-set-active-layer img (aref (cadr layers) 1))
; cut A1, paste into layer, and anchor (gimp-image-set-active-layer img (aref (cadr (gimp-image-get-layers img)) 3))
(gimp-edit-cut (aref (cadr (gimp-image-get-layers img)) 3)) (gimp-image-set-active-layer img (aref (cadr (gimp-image-get-layers img)) 0))
; (gimp-floating-sel-anchor (car (gimp-edit-paste drawable TRUE)))
; move L back to top ; (gimp-image-raise-layer-to-top img (aref (cadr layers) 0)) ; (gimp-image-set-active-layer img (aref (cadr (gimp-image-get-layers img)) 0))
) ; let*
; Flush the display (gimp-image-undo-group-end img)
(gimp-displays-flush)
(script-fu-register "LAB-Enhance" "LAB-Enhance"
"Perform LAB Enhancement" "David Hathaway " "(c) David Hathaway" "2009 10 21"
"GRAYSCALE*"
SF-IMAGE "Image" 0 SF-DRAWABLE "Layer to start on (unused)" 0) (script-fu-menu-register "LAB-Enhance" "/Filters/Dave77459")
