not working
not working Mary Dargis 12 Aug 01:28
  not working Noel Stoutenburg 12 Aug 01:45
  not working G J J 12 Aug 03:06
  not working Martin Nordholts 12 Aug 06:47
   not working jolie 12 Aug 19:04
Mary Dargis
2009-08-12 01:28:11 UTC (over 15 years ago)
not working
hi,
I have a new hp laptop running vista x64  i have installed and uninstalled gimp a few times and keep getting the message that gimp has stopped working. In between installations i have removed everything gimp as to start fresh. I tried running as administrator, no luck. Can yo please help me. I have done all my work on gimp and am very frustrated. mambus2000@yahoo.com
M. Dargis
Noel Stoutenburg
2009-08-12 01:45:34 UTC (over 15 years ago)
not working
First question to ask is if whether or not you are using the installers for 32 or 64 bit Windows. I am running Gimp 2.6.6 for Windows on 64 bit XP SP3, without any difficulty, though it appears I may have intstalled using the 32 bit version.
ns
G J J
2009-08-12 03:06:25 UTC (over 15 years ago)
not working
try vers 6.2.4
you could always return and get your money back, I hear they let you keep using it after that.
lol
seriously, i cant get the newer versions to run on my Vista
To: gimp-user@lists.XCF.Berkeley.EDU
Sent: Tuesday, August 11, 2009 6:28:11 PM
Subject: [Gimp-user] not working
hi,
M. Dargis
Martin Nordholts
2009-08-12 06:47:57 UTC (over 15 years ago)
not working
On 08/12/2009 01:28 AM, Mary Dargis wrote:
hi,
The Windows installers for GIMP 2.6.5 and GIMP 2.6.6 is packaged wrongly and will only keep from crashing with luck.
You should either use GIMP 2.6.4 or wait for GIMP 2.6.7 to be released, which should be soonish.
/ Martin
2009-08-12 19:04:35 UTC (over 15 years ago)
not working
hi,
/ Martin
Hi Mary,
You asked for some help with installing 2.6.4 I think.
Go here http://www.gimptalk.com/forum/gimptalk-glossary-&-faq-look-here-before-asking?-t26068.html
and scroll down to "how to do a clean install of GIMP" and follow the steps. If step 1 is confusing just do the steps after you've just started up your computer. You can skip step 1 if you do it when you've just started up your computer.
At step 7 you need to download version 2.6.4 that you can find here http://www.filehippo.com/download_the_gimp/5072/
Hope this helps!
jolie
