help with compilation
9 of 9 messages available
help with compilation Josenildo Marques 15 Jan 20:31
  help with compilation Joao S. O. Bueno 15 Jan 20:37
  help with compilation Sven Neumann 15 Jan 22:06
   help with compilation Thomas Spuhler 15 Jan 22:27
    help with compilation Josenildo Marques 15 Jan 23:56
     help with compilation Sven Neumann 16 Jan 01:04
      help with compilation Josenildo Marques 16 Jan 09:38
       help with compilation Sven Neumann 16 Jan 12:45
help with compilation misfit-x 15 Jan 21:26
Josenildo Marques
2004-01-15 20:31:50 UTC (over 21 years ago)
I'm trying to compile The Gimp 2.0. I get the output below when running ./configure
checking for librsvg-2.0 >= 2.2.0... Package librsvg-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `librsvg-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'librsvg-2.0' found
configure: WARNING: *** SVG import plug-in will not be built (librsvg not found) ***
What I have on my system is [root@kali cyb]# rpm -qa | grep librsvg librsvg2_2-2.4.0-1mdk
librsvg-2.4.0-1mdk
checking for gimpprint-config... no configure: error:
*** Check for libgimpprint failed. You can download it from *** http://gimp-print.sourceforge.net/ or you can build without it by passing
*** --disable-print to configure (but you won't be able to print then).
But I have [root@kali cyb]# rpm -qa | grep libgimpprint libgimpprint1-4.2.5-30mdk
What can I do to proceed ? TIA
Joao S. O. Bueno
2004-01-15 20:37:06 UTC (over 21 years ago)
checking for librsvg-2.0 >= 2.2.0... Package librsvg-2.0 was not found in the pkg-config search path. Perhaps you should add the directory containing `librsvg-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'librsvg-2.0' found
librsvg-2.4.0-1mdk
urpmi librsvg2_2-devel
misfit-x
2004-01-15 21:26:26 UTC (over 21 years ago)
Try this:
# locate librsvg-2.0.pc (take note of the path) # export PKG_CONFIG_PATH=(path as above minus the *.pc file)
Then make clean and try configure from scratch.
.:: misfit-x ::.
2004-01-15 22:06:48 UTC (over 21 years ago)
Josenildo Marques writes:
librsvg-2.4.0-1mdk
If you want to compile GIMP or any other application against librsvg, you will need to install the librsvg development package as well. What you installed so far only allows you to run an application that's using librsvg, it doesn't allow you to compile one.
Thomas Spuhler
2004-01-15 22:27:16 UTC (over 21 years ago)
This is what I have :
librsvg2_2-2.4.0-1mdk librsvg2_2-devel-2.4.0-1mdk
librsvg-2.4.0-1mdk
Tom
librsvg-2.4.0-1mdk
Josenildo Marques
2004-01-15 23:56:21 UTC (over 21 years ago)
librsvg-2.4.0-1mdk
Tom
Hi.
It's done and I have already installed it. I's perfect ! However, I installed it with rpm -i and the docs (and probably other stuff, too) have not been installed. I'd appreciate if you could give me some hints. I have tried to uninstall it and I can't. TIA
************************************** **** RPM package creation selected *** **************************************
Building RPM package...OK
NOTE: The package will not be installed
Erasing temporary files...OK
Deleting doc-pak directory...OK
Writing backup package...OK
Deleting temp dir...OK
Done. The new package has been saved to
/usr/src/RPM/RPMS/i586/gimp-2.0pre1-1mdk.i586.rpm
You can install it in your system anytime using:
rpm -i gimp-2.0pre1-1mdk.i586.rpm
[root@kali gimp-2.0pre1]# cd /usr/src/RPM/RPMS/i586/ [root@kali i586]# l
[root@kali i586]# urpmi gimp
gimp gimp2-gap gimp1_3 gimp-data-extras gimp1_3-python gimp-doc gimp-2.0pre1-1mdk.i586.rpm gimp-perl gimp2-freetype gimpprint [root@kali i586]# urpmi gimp-2.0pre1-1mdk.i586.rpm The following packages have to be removed for others to be upgraded: gimp-1.2.5-6mdk.i586 (in order to install gimp-2.0pre1-1mdk.i586) gimp-doc-1.2.5-6mdk.i586 (due to conflicts with gimp[
[root@kali i586]# rpm -i gimp-2.0pre1-1mdk.i586.rpm [root@kali i586]#
2004-01-16 01:04:08 UTC (over 21 years ago)
You should consider to rename the package to gimp2.0 or gimp2 so that the full package name becomes gimp2.0-2.0pre1 or gimp2-2.0pre1. Then it could coexist with the gimp package (that should have been called gimp1.2 to begin with).
Josenildo Marques
2004-01-16 09:38:41 UTC (over 21 years ago)
I renamed it to gimp2.0 and installed it. rpm -i -v gimp2.0-2.0pre1-1mdk.i586.rpm
It is installed as gimp-1.3. Is this correct ?
It does not seem to have the help files...I'd like to have some tips about the new user interface.
TIA
2004-01-16 12:45:49 UTC (over 21 years ago)
Yes, the executable and the libraries will continue to be called 1.3 until the first release candidates for 2.0 are released.
Help files will be packaged and distributed separately for gimp-2.0. There's also still lots of content missing and we could need your help with that.
