batches for web
7 of 9 messages available
batches for web alec 02 Jul 21:43
  batches for web Sven Neumann 02 Jul 22:06
   batches for web Jay Smith 02 Jul 22:38
20090703044059.GC22586@shal... 07 Oct 20:20
  batches for web alec 07 Jul 06:27
   batches for web Bob Long 07 Jul 07:41
   batches for web Michael Schumacher 07 Jul 13:47
   4A53D72B.4070107@yahoo.com Patrick Horgan 08 Jul 01:15
    batches for web David Gowers 08 Jul 03:19
alec
2009-07-02 21:43:26 UTC (over 16 years ago)
batches for web
Howdy...
I finally installed David's Batch Processor (after months of trying to figure out how to do batches) but I'm surprised that I don't see an option for changing resolution. I'm simply trying to prepare images(lots of them) for the web. Did I miss something in Daves Batches? Or maybe someone has a link to something else that would work for me? Thanks!
-Alec
2009-07-02 22:06:45 UTC (over 16 years ago)
batches for web
Resolution (as in dots-per-inch) is irrelevant for images used on web-pages. The only thing that counts is the number of pixels.
Jay Smith
2009-07-02 22:38:53 UTC (over 16 years ago)
batches for web
But... resolution is important for print output ... which is something I am interested in.
So I think Alec's question still stands.
Jay
alec
2009-07-07 06:27:23 UTC (over 16 years ago)
batches for web
Hi...
Akkana Peck wrote:
Does Resize not do what you want? (I don't have DBP installed right now, but I thought it could scale images and looking at the web page I would guess Resize is what does that.)
Do you have a link to that plugin? I've searched quite a bit and David's Batch processor has seemed the best so far, but I'm still(after a couple years now) new to GIMP.
...Akkana
Huh, I thought that lower resolution would make the file size smaller so web images would load faster. No?
Thanks- Alec
Bob Long
2009-07-07 07:41:08 UTC (over 16 years ago)
batches for web
Depends what you are *really* referring to. See http://www.scantips.com/basics01.html
2009-07-07 13:47:05 UTC (over 16 years ago)
batches for web
Von: alec
Absolute resolution (aka 'image size'): yes
Relative resolution (aka 'pixels per inch'): no
See also "72 dpi myth", e.g. at http://www.scantips.com/no72dpi.html
HTH, Michael
David Gowers
2009-07-08 03:19:41 UTC (over 16 years ago)
batches for web
On Wed, Jul 8, 2009 at 8:45 AM, Patrick Horgan wrote:
The truth is that Gimp displays to you using your screen resolution, so if you originally created an image at 72dpi and 216x216 pixels and another image at 4800dpi and 216x216 pixels, Gimp will display them the same.
Sort of true, see below..
While
they look the same, if you look at image properties with or set the disply units to inches in the bottom border and move around the image, you can see the difference.  One is reported as 3" across and the other as .045" across.  The resolution is used by Gimp to translate to inches and inch derived units for you.
If you go into image/resize, and only change the dpi, Gimp will report to you that the image is a different size in inches, but the pixels are not in any way changed.
Various image file types like jpg and png store resolution and Gimp does store that for you.  Devices are supposed to scale the images so that on their display resolution they will appear the same size as in the images native resolution.  Some devices/software actually do this.
Like GIMP (toggle View->Dot for Dot off). When Dot for Dot is off, GIMP displays the image at a scale matching the comparitive resolutions of the screen and the image.
  If you print
something and it comes out the wrong size, some times you can open it in Gimp, change the resolution and resave.  The only change will be in the stored resolution, the file's image data is completely unchanged, yet it will now print a different size!
