mng problem
mng problem manwithcake 12 May 03:09
mng problem Jernej Simon?i? 12 May 11:24
  mng problem manwithcake 13 May 05:07
mng problem Jernej Simon?i? 13 May 08:53
2009-05-12 03:09:15 UTC (almost 16 years ago)
mng problem
When I start gimp, I get the message "the procedure entry point mng_create could not be located in the dynamic link library libmng.dll"
I have the libmng.dll in both the gimp and windows/system32 folders.
Gimp runs fine, but this is a bit annoying.
WinXP home edition.
Jernej Simon?i?
2009-05-12 11:24:25 UTC (almost 16 years ago)
mng problem
Remove the one in system32 directory, it has no place being there (and when some other program breaks later, complain to that program's author for screwing up your system).
2009-05-13 05:07:19 UTC (almost 16 years ago)
mng problem
Thanks, that did the trick. No idea how that extra file got in the windows folder.
Jernej Simon?i?
2009-05-13 08:53:22 UTC (almost 16 years ago)
mng problem
Some broken program put it there. You'll find out which one when it'll stop working.
