blur between images
9 of 9 messages available
blur between images shacoshe 04 May 10:27
  blur between images David Gowers 04 May 10:59
   blur between images shacoshe 04 May 11:26
    blur between images shacoshe 04 May 15:21
     blur between images Chris Mohler 04 May 17:26
  blur between images g mohler 05 May 03:18
blur between images Alchemie foto\\grafiche 05 May 02:22
  blur between images shacoshe 05 May 10:15
   blur between images shacoshe 05 May 10:26
2009-05-04 10:27:24 UTC (about 16 years ago)
blur between images
hello i want to create a texture for a 3d model
so i took couple pictures of my face from different angels
and i tried to blur where the images connects using clone tool
i used the clone tool more then an hour and the result is not close to what i want
my question is:
is there is any way i can get result faster
you can see the image here
http://blenderartists.org/forum/showthread.php?t=154621
thank you
David Gowers
2009-05-04 10:59:38 UTC (about 16 years ago)
blur between images
my question is:
Use Hugin to merge the images in a smart way. IMO there is no reason to use GIMP to build the texture (except perhaps tiny cosmetic touchups of the result of Hugin)
2009-05-04 11:26:52 UTC (about 16 years ago)
blur between images
thank you david
i was searching the net before posting the question first time i eared of hugin for make a face texture
can hugin make the blur look really clear ? (ill try it when ill get home
hope wont take me a month to learn a new program)
here is one for example of using gimp to do so http://wiki.cgsociety.org/index.php/Portrait?thumbnail
if i will chose gimp ,cause i know it a bit. what will be the best and fast way to do it ?
thanks again
my question is:
2009-05-04 15:21:42 UTC (about 16 years ago)
blur between images
any one can help me to do it with gimp?
thank you david
thanks again
my question is:
Chris Mohler
2009-05-04 17:26:30 UTC (about 16 years ago)
blur between images
From the tutorialo/article:
"There are no magic formulas for this operation, just painstaking cutting, assembling, fitting and filling in missing pieces, erasing shadows, toning down the hair, until we get a usable texture. "
Chris
2009-05-05 02:22:30 UTC (about 16 years ago)
blur between images
hello i ?want to create a texture for
a 3d model
my question is:
is there is any way i can get result faster:
Yes with the resynthesizer plugin.
(or with hugin but, if only for that hugin may be a overkill )
g mohler
2009-05-05 03:18:59 UTC (about 16 years ago)
blur between images
use hugin.
it's a stitching program for fitting images together.
if you run linux and like command-line style you can skip hugin using multiple applications such as: nona, enblend, enfuse, etc.
doing that in the GIMP sounds like a pain in the ass. you can find google results of the GIMP verses hugin. hugin wins. it can correct perspective, angles, ev diff's, etc. check out some of the tutorials beforehand and see if it fits the bill.
for what you seem to be doing (i may be wrong) i highly recommend hugin.
g.
my question is:
thank you
-- shay t. (via www.gimpusers.com)
2009-05-05 10:15:48 UTC (about 16 years ago)
blur between images
thank you ill give it a try
you know any good tutorials for using the resynthesizer plugin
a 3d model
my question is:
2009-05-05 10:26:16 UTC (about 16 years ago)
blur between images
ok not allot of options ,
i played with is a bit .
it could do a nice job
a 3d model
my question is:
