Ctrl, Shift, Alt
Ctrl, Shift, Alt DJ 24 Apr 00:04
  Ctrl, Shift, Alt David Gowers 24 Apr 04:18
DJ
2009-04-24 00:04:46 UTC (about 16 years ago)
Ctrl, Shift, Alt
Hi Gimp-user,
I was trying out Gimp's various Selections, and tools. Clicking on the Ctrl, Shift, and Alt keys, before a left-click and after a left-click, changes the Action.
Sometimes there is helpful text in the status bar at the bottom of the Image telling the user to try these keys. I find it helpful to have the specific Tool's options open too, because it may provide a visual indicator what these keys will do (i.e., highlight an option or check/uncheck a checkbox).
I like this feature, and especially the text in the status bar. It's very helpful. It really pays, at the beginning, to move slowly, and read that text in the status bar after clicking.
I was wondering, is it pretty much a given that all Tools support Ctrl, Shift, Alt, before and after a left-click? That would be the only combination of keys and mouse clicks, no?
I did checkout the section "Keys and Mouse References" in the Documentation. And found the neat Quick Reference [http://docs.gimp.org/quickreference/]. Unless, I just missed it, none of these mention the mouse and these keys.
Thank you.
David Gowers
2009-04-24 04:18:38 UTC (about 16 years ago)
Ctrl, Shift, Alt
On Fri, Apr 24, 2009 at 7:34 AM, DJ wrote:
Hi Gimp-user,
Yes -- this is indicated by the tooltips when you hover over the 'replace'/'add'/'subtract'/'intersect' icons, as well as the
No (although all selection tools do.). For instance, most paint tools don't support Alt, since there is no sensible action to map to this (whereas CTRL = pick color or set source location, SHIFT = draw line from last point) Some tools support none of the modifiers at all, for the same reason. (eg color tools like Curves, Levels, etc.)
Yes. The ctrl/shift/alt behaviour is complex for some of the selection tools, so doesn't easily fit in a quick reference. OTOH, the ctrl/shift behaviour for paint tools is simple enough that it should probably be in the quick reference.
In the main documentation, these actually are documented -- see
http://docs.gimp.org/en/gimp-tools-selection.html#gimp-tool-select
If you think this could be made more obvious or accessible, I encourage you to contribute to the documentation project (see http://docs.gimp.org/help.html )
David
