Animated and unanimated
Animated and unanimated Maureen 28 Mar 22:58
  Animated and unanimated Olivier Lecarme 29 Mar 08:46
Maureen
2009-03-28 22:58:14 UTC (about 16 years ago)
How do I put together a graphic that has part of it animated and part not? I have started with an animated .GIF file, added a .JPEG file to it and then saved it as an animated file. This makes the .JPEG file blink on and off while the other animation is running. For instance, I have put text on top of an animation, but I don't want the text to be animated. How do I do this?
Thanks.
Maureen
Olivier Lecarme
2009-03-29 08:46:06 UTC (about 16 years ago)
So you want the text to appear in every frame of the animation, i.e. every layer of the GIF image. I assume your frames are in replace mode. Thus you need to copy the text on every frame. If the number of frames is not very high, it is only a matter of a few click:
1 place the text layer at the bottom of the layer stack, just above the background;
2 duplicate the text layer;
3 merge the bottom layer of the pair just built with the underlying layer;
4 move up the remaining text layer by one layer; 5 go back to step 2 until you are at the top layer.
If there are a lot of frames in your animation, using the GAP plugin would be better.
