GAP PLUGIN INSTALL HELP
5 of 6 messages available
GAP PLUGIN INSTALL HELP bluerhapsohdy@aol.com 27 Feb 00:44
  GAP PLUGIN INSTALL HELP firestick 27 Feb 13:50
GAP PLUGIN INSTALL HELP bluerhapsohdy@aol.com 27 Feb 14:29
  GAP PLUGIN INSTALL HELP Torsten Neuer 27 Feb 14:37
mailman.239656.1235708616.1... 07 Oct 20:19
  GAP PLUGIN INSTALL HELP Alchemie foto\\grafiche 27 Feb 16:31
2009-02-27 00:44:32 UTC (about 16 years ago)
Hello folks.
So I just got Gimp. I like it a lot, and I saw that there is an animation plugin. I downloaded but now i don't know what to do with it. I found the plugin in folder but idk whether i'm supposed to extract all the files to the plugin folder or if certain files go to certain folders.
I'm using Windows XP 2004. If anyone who has installed the animation plugin or knows how to can help, it would be greatly appreciated.
Logic.
************** A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
(http://pr.atwola.com/promoclk/100126575x1218822736x1201267884/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26 hmpgID%3D62%26bcd%3DfebemailfooterNO62)
firestick
2009-02-27 13:50:18 UTC (about 16 years ago)
Did you read this (taken from http://gimp.org/docs/userfaq.html#Plugin):
How do I add new plug-ins? First, copy the plug-in[s] to your plug-in directory (in GIMP folder). After copying the plug-in to its proper directory, just run GIMP. It should automatically find new plug-ins. ...?
I don't know why the animation plugin would be different from the rest. The website has much more info than I do on installing plugins. Good luck!
2009-02-27 14:29:08 UTC (about 16 years ago)
Yeah i've read the "How do I add plugins?" but i still don't know which directory to put it in. When i go to my plugins folder, I see a lot of application files. And there are a million different folders outside of that so if i need to put each file in different folders then i'll do that, but i need to know where to put them.
When i downloaded GAP it was a bunch of files in one folder. I just need to know where that folder goes so I can start using it. Does anyone know what the address of that folder is or can someone please check for me. Thanks a lot.
(http://pr.atwola.com/promoclk/100126575x1218822736x1201267884/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D6 2%26bcd%3DfebemailfooterNO62)
Torsten Neuer
2009-02-27 14:37:39 UTC (about 16 years ago)
Am Freitag, 27. Februar 2009 14:29:08 schrieb bluerhapsohdy@aol.com:
Actually, you can put it whereever you like (as long as it fits the file system layout of your OS and you have write access during installations time) and add the installation directory to the plugins settings in the settings dialog. This is also the method that should be used for any plugins that do not come with the main gimp package.
hth
Torsten
2009-02-27 16:31:55 UTC (about 16 years ago)
First i doubt you have found the right installer because that more easy to trace was obsolete even for Gimp 2.4, and work as should only with gimp 2.0 or gimp 2.2...i will not use it with last stable gimp
Then there is a more recent installer, is not yet perfectly updated to work with gimp 2.6 (all problem are already fixed in the source code but nobody till now was able or find the time to compile for Windows)but will work much better on gimp 2.6 and perfectly on gimp 2.4
Here the link on top ,on the first message highlighted in red updated download links,
http://www.gimptalk.com/forum/gimp-gap-2-4-0-for-windows-t28692.html
Pack contain a how to install and a good and clear guide for use,
let me know if that help or if you enconter any other related problem
PS Jernej Simon?i? any hope for a windows build of GAP as from the last svn ? That will fix most of compatibility problem with Gimp 2.6 the build you host is unusable since gimp 2.4 popped out.
Hello folks.
Logic.
Passa a Yahoo! Mail.
La webmail che ti offre GRATIS spazio illimitato, antispam e messenger integrato.
http://it.mail.yahoo.com/
