Script-fu for multi-language
Script-fu for multi-language Tetsuya Yuasa 26 Feb 20:27
  Script-fu for multi-language saulgoode@flashingtwelve.brickfilms.com 27 Feb 17:37
   Script-fu for multi-language Tetsuya Yuasa 27 Feb 19:58
    Script-fu for multi-language Marco Ciampa 27 Feb 22:52
     Script-fu for multi-language Tetsuya Yuasa 01 Mar 11:16
Tetsuya Yuasa
2009-02-26 20:27:54 UTC (about 16 years ago)
I've writed some script-fu and I want to know how can I rewrite it for multi-language, exactly said, for two-language.
Of course I can write it by separated files, but it bothered me when I need to rewrite the script.
Is there any document about it?
I would appreciate any your help.
2009-02-27 17:37:50 UTC (about 16 years ago)
Quoting Tetsuya Yuasa :
There are probably people better qualified to answer your questions, and I may even be giving bad advice; however, my understanding is that you should mark strings in your script which you want translated with an underscore.
_"this text should be translated"
Such text strings will then be handled, not by GIMP itself, but by GLIB based on the user's LOCALE setting. Of course, a translated substitute must be provided and that should be coordinated with the translation team for the language which you wish to have supported.
A list of the translation teams for various languages is available at http://l10n.gnome.org/teams/ . If you contact the appropriate team for your language, they should be able to provide much better guidance.
Tetsuya Yuasa
2009-02-27 19:58:32 UTC (about 16 years ago)
Thanks for your help!
Your advise helped me so much. :)
Marco Ciampa
2009-02-27 22:52:57 UTC (about 16 years ago)
See also the gettext package documentation for increase your knowledge on the subject.
bye
Tetsuya Yuasa
2009-03-01 11:16:24 UTC (about 16 years ago)
Thanks a lot :)
I'll see about it.
