Color Discrepency
Color Discrepency D.Jones (aka) Capnhud 05 Feb 03:10
  Color Discrepency David Gowers 05 Feb 03:59
2009-02-05 03:10:31 UTC (about 16 years ago)
Color Discrepency
I am not quite sure why this is happening but I notice that sometime when I download images and open them in the gimp the color that I may have seen in the web browser is definitely not the same color that I see in the gimp.
For example this image http://img6.imageshack.us/my.php?image=colordifferencexg2.png
show such a discrepency in which the red in the browser is brighter than the red in the Gimp.
How do I correct this
David Gowers
2009-02-05 03:59:34 UTC (about 16 years ago)
Color Discrepency
Hi!
You use a browser that has proper color management.
Or you can disable color management in GIMP; or assign 'standard srgb' color profile to the image. To be correct, however, you probably should convert the image to 'standard srgb' color profile. (the Image->Mode menu allows you to assign and convert to profiles)
To be completely clear: GIMP is probably showing the image correctly, while your browser is wrongly assuming that the image is stored with standard srgb color profile.
David
