Question: How to....
Question: How to.... Rlt46gem@aol.com 28 Jan 21:04
  Question: How to.... Mark J. Reed 28 Jan 21:09
  Question: How to.... Daniel Hornung 28 Jan 21:09
Rlt46gem@aol.com
2009-01-28 21:04:16 UTC (about 16 years ago)
I have Gimp 2.6. It says I need to "install the additional help package". Where do I find the download?
Rebecca
"Belief" is compatible with respect and tolerance for other beliefs. "Certainty" is an arrogance that leads to intolerance, disrespect and, all too often, terror and war. --Ray Sachs, quoted from Newsweek Letters 9/25/06
Totally cool web site:_ Tolerance.org_ (http://www.tolerance.org/index.jsp) *~*~*~*~*~*~*~*~*~*~*~*~*
ANYTHING BEYOND THIS POINT IS ADVERTISING ADDED BY AOL WITHOUT MY PERMISSION OR CONSENT
**************A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
(http://pr.atwola.com/promoclk/100000075x1215855013x1201028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=De cemailfooterNO62)
Mark J. Reed
2009-01-28 21:09:10 UTC (about 16 years ago)
Wherever you downloaded the Gimp itself. :) If you installed a binary package, there should be a help package nearby.
For Ubuntu Linux, "sudo apt-get install gimp-help-en" will get the English version of the help.
Daniel Hornung
2009-01-28 21:09:14 UTC (about 16 years ago)
Rebecca
Usually at the same place you found GIMP itself, which usually depends on your operating system.
Daniel
