What is the best white balance script/plugin?
What is the best white balance script/plugin? Ken Warner 24 Jan 05:14
  What is the best white balance script/plugin? Claus Cyrny 24 Jan 10:32
Ken Warner
2009-01-24 05:14:55 UTC (about 16 years ago)
I need to white balance some panoramas shot under high frequency florescent light. I've googled around. Apparently there is a bunch of scm around. Which is the best?
The way I would *like* to do it is to use the color picker and select the white object in the panorama and say go.
My raw converter works this way but I shot JPEG.
What is the favorite white balance correction method/script/plugin for the GIMP'rs?
Claus Cyrny
2009-01-24 10:32:50 UTC (about 16 years ago)
Why don't you just use Gimp's 'Colors > Levels'? There's exactly the kind of color picker you would like to have. You can select both black & white point, you have the option 'auto', you can apply 'Levels' to one specific channel, etc.
Claus
