2 questions about layers and selection
2 questions about layers and selection poppe 11 Jan 15:44
  2 questions about layers and selection Martin Nordholts 11 Jan 15:54
  2 questions about layers and selection saulgoode@flashingtwelve.brickfilms.com 11 Jan 16:46
   2 questions about layers and selection poppe 13 Jan 18:16
2009-01-11 15:44:07 UTC (almost 17 years ago)
Hello
How can i select multiple layers at once? For example when i want to delete 10 layers at once.
Where can i see what my selection size is? It tells nowhere what the selection size is after releasing mousebutton.
Martin Nordholts
2009-01-11 15:54:11 UTC (almost 17 years ago)
poppe wrote:
Hello
Hi
You can currently only select on layer at a time.
The size of the selection can easily be seen in Windows -> Dockable Dialogs -> Pointer, but you need GIMP SVN trunk for that (i.e. it will be in GIMP 2.8). The enhancement request was: Bug 138101 – Pointer (Information) tab should display selection bounds http://bugzilla.gnome.org/show_bug.cgi?id=138101
BR, Martin
2009-01-11 16:46:32 UTC (almost 17 years ago)
Quoting poppe :
About the only support for "selecting of multiple layers" is to chainlink them, and this only helps you operate on them as a group for the transformation tools (move, rotate, scale, etc).
The easiest work-around is to hide all of the layers you want to keep, merge the visible layers, then delete the resulting merged layer (and unhide the retained layers).
Again, not directly possible in current GIMP (expect it in the next version). A kludgy work-around is to float the selection and open the scale layer dialog -- the dimensions of the selection will be the layer bounds. CANCEL the dialog and perform an UNDO to return to your original image.
2009-01-13 18:16:45 UTC (almost 17 years ago)
Hi
I hope deleting multiple layers at once is added also. Sometimes i have tens of layers i need to work on, and it would help alot.
For example:
While pressing shift, you can select multiple layers. Then by pressing delete they would be deleted.
Thank You Poppe
Quoting poppe :
