is there a way to change default brush spacing?
is there a way to change default brush spacing? BEIGE 04 Jan 22:42
  is there a way to change default brush spacing? David Gowers 04 Jan 23:18
  is there a way to change default brush spacing? tin 07 Feb 20:36
2009-01-04 22:42:48 UTC (over 16 years ago)
I'm reviewing Gimp 2.6.4 and this is the first in a long list of stupid questions I'll be asking. Since pixmap brushes can't be edited and their spacing isn't stored across relaunches, can you edit the default spacing of brushes? 25 is waaaaaaaaaaaay too big and I'm getting bad stepping with my imported PS brushes.
David Gowers
2009-01-04 23:18:45 UTC (over 16 years ago)
PS brushes != pixmap brushes. (I can edit pixmap brushes myself, just fine.)
I believe it is currently assumed that the user will re-save a brush with adjusted spacing if this is important This is debatable IMO. In this situation I think making an ABR load/save plugin from the current code in the core is the right way to address this.
http://bugzilla.gnome.org/show_bug.cgi?id=531326
David
2017-02-07 20:36:15 UTC (about 8 years ago)
I just followed some tutorial and it required changing brush spacing. And I had to play around to find out where it is. It's not very intuitive in GIMP. So I wrote a graphical guide to show you how to change brush spacing in GIMP. http://bakon.ca/gimplearn/how-to-change-brush-spacing-in-gimp-385
